CLEARANCE STRIP!!!!
Old May 7, 2004 | 10:38 AM
acehigh1977's Avatar
CLEARANCE STRIP!!!!
Can anyone tell me how to install new bulbs into the clearance strip so that it matches my clear corners.....Is it easy to do???
Old May 7, 2004 | 10:40 AM
hoshtaylor's Avatar
Re: CLEARANCE STRIP!!!!
It's very easy. Remove the three plastic pins that hold the wheel well guard in place. The bulbs are the same as the ones that go in your clear corners... 168 Wedge Bulb.
"Operator, give me the number for 911!"
- Homer Simpson
Old May 7, 2004 | 10:42 AM
what pins that hold the wheel well guard in place????
Old May 7, 2004 | 10:50 AM
scottkusf's Avatar
Turn the wheels all the way to one side, depending on which side you are doing. Then look inside the wheel well. You will see these little round clips. You have to pull the center of them outwards to release the grip. Then there might be 2 screws you have to take out. Just keep doing that till enough of the wheel well can be pulled down to gain access to the light.
2004 6MT Coupe Graphite/Graphite / Performance / Premium / Sirius / Navigation / Clear Bra / Aero / Trunk Mat
Old May 7, 2004 | 12:19 PM
Shader7's Avatar
I think there's a DIY about this. I've done it both ways, removing the wheel and not removing the wheel. Taking the wheel off (if you are able), makes it far easier.
Black/Willow 03.5 6MT, Premium, Navi, Aero, SAT
350Z Nismo CAI
hoshtaylor's Avatar
All you need is a small flat head screwdriver to pull the middle of the plastic pins out, and a phillips screwdriver for the screw...can't remember if there is one or two screws...
- Homer Simpson
Old May 7, 2004 | 01:14 PM
TCFOOL's Avatar
Try looking at the pics I have in my album to see where the clearance light is...Wheels off makes it very easy...
http://www.imagestation.com/album/?id=4289515101
TC
[img]/w3timages/icons/tongue.gif[/img]
"There is a Very Fine Line Between "Hobby and Mental Illness"
Old May 7, 2004 | 03:31 PM
Meatshackle's Avatar
Deep Sea Moderator
It's even easier if you jack that tire up a little.
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest Monitors Thread
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
mike730
Jan 12, 2018 04:25 PM
alessandro
Oct 8, 2015 09:29 AM
Ashton35
Jul 17, 2015 10:11 AM
