Just got my G35 today and need some help
Old Sep 1, 2008 | 01:34 AM
StriderX303's Avatar
Hey everyone, I'm a long time reader but a first time poster. Here's my situation.
I just got my g35 in today and I love everything about it except I have a problem with the dashboard lights and radio lights. Every time I turn the headlights to the ON or AUTO positions, all the lights from my dashboard (speedometer, miles, gas, etc) and my radio lights turn off. When I turn the headlights off, all the lights come back on. As you can tell, this is not a good thing cuz i can't see anything when I drive it at night. Any suggestions?
Thanks
Old Sep 1, 2008 | 01:36 AM
Invalid_User's Avatar
maybe you have it set to off on the dash lights
Old Sep 1, 2008 | 01:46 AM
sorry if this sounds like a NOOB question but where can i turn it on or off on the dash lights?
G35Now!'s Avatar
Moderation-free
+1 - Find the control for the dash lights, should be a dial on the dash close to the steering wheel (sorry, not positive where it is for the coupes). If it's set to off, when the headlights / side lights come on your dash lights will go off.
Old Sep 1, 2008 | 01:47 AM
its gonna be to your bottom left by the steering wheel, its where the trunk,and vdc off button is
Old Sep 1, 2008 | 02:08 AM
Thanks for the quick replies, I located the controls for the dashlights, messed around with it by turning the the little wheel **** up and down and my dashboard lights still goes off when I turn on the headlights.
Old Sep 1, 2008 | 02:16 AM
hmmm weird, fuse maybe?
Old Sep 1, 2008 | 02:18 AM
if it's only a fuse then how much are we looking at to get it fixed? I also want to mention that all the lights including the lights for the temperature buttons goes off when the headlights are on but works fine when the headlights are off.
Old Sep 1, 2008 | 02:32 AM
man the only thing i can think of would be the dash light you sure you have it set to on , has to make a lil click sound to know when its on
Old Sep 1, 2008 | 02:45 AM
yup...i made sure...i even messed around with it too like i said earlier...i guess i'm out of luck with this one
Old Sep 1, 2008 | 11:30 AM
rob40wilson03's Avatar
if its a fuse.... you're looking at paying less money to fix it than the gas you'll use driving to autozone to get a new fuse
it could just be something screwy the circuit (maybe the dealer had to mess with it for some reason and somehow it got out of sync).... anyway i would take it to where ever you bought it and tell them about it if it turns out not to be a fuse
Old Sep 1, 2008 | 12:55 PM
silver g's Avatar
It sounds like your dash lights are set too dim. It can be adjusted on your lower left of the steering wheel by the tab where you pop the trunk.
EDIT: OOps I read further and found out you tried this...so NM
Old Sep 1, 2008 | 01:02 PM
gary c's Avatar
I don't believe our members don't know the answer to this issue!
In the daytime when you turn your headlights on the interior lights go to
evening mode. When it gets dark turn on your headlights and see what I'm
refering to. You don't need your headlights in the daytime....right?
Gary
Old Sep 1, 2008 | 02:46 PM
Gary
the lights DIM at night.... but they obviously aren't supposed to go OFF
Old Sep 1, 2008 | 09:19 PM
dave's Avatar
I know you said you messed with it, but try this:
Turn the headlights on, and then roll the little wheel all the way up.
If that doesn't work, check to make sure that the wiring harness for the wheel is plugged in.
