Low Brake Fluid Lite ON
Old Sep 4, 2008 | 11:04 AM
chaitG35's Avatar
I have 05, G35 6MT. Yesterday I saw the low brake fluid lite warning on.
Can you guys suggest what is the recommended brake fluid to be used in the G35?
Old Sep 4, 2008 | 11:11 AM
uf20wop's Avatar
it should say in the back of the owner's manual what type to use
it's in my car, i can look @ lunch
Old Sep 4, 2008 | 11:12 AM
uf20wop's Avatar
but you should check to make sure you're not leaking anywhere, brake fluid doesn't really get used up
Old Sep 4, 2008 | 11:18 AM
chaitG35's Avatar
Yes, it said DOT 3 fluid.
I was looking for any particular brand that Infiniti recommends.
A week ago I had my car scratch under the body really bad when I was backing out of the parking lot...not sure if caused any damage to cause brake leakage... damn
Old Sep 4, 2008 | 03:23 PM
Curt G's Avatar
It doesn't get "used up" but it does get transferred from the master cylinder to the brake calipers as the brake pads get worn down. I've noticed on other cars that when my fluid light comes on it usually means the pads are close to needing to be replaced.
Old Sep 4, 2008 | 03:30 PM
Boston's Avatar
+1...check your pads. Fluid warning light is usually a good indication that your pads are worn.
Old Sep 4, 2008 | 04:06 PM
uf20wop's Avatar
cool good to know... that makes sense
Old Sep 7, 2008 | 02:46 AM
mediabox's Avatar
yep agree with the prior posts. just to double check, look on the ground for any leaks and look in the resovior to make sure there is some fluid still left - it doesn't hurt to fill it up i'd say 1/2 way between min and max. if for some reason you do have a leak your brakes will fail.
note: if you brakes do fail, remember to pump them and you should get one last stop out of them.
laksjd84
Feb 28, 2026 01:58 PM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
linedr89
Aug 17, 2015 05:11 PM
mushu
Jul 15, 2015 03:55 PM
