Vibration in the shifter, help
Old Oct 6, 2008 | 02:37 PM
Degmidgetg35's Avatar
Hey guys when i drive the car this is quite a bit of vibration in the shifter, i know there should be some but this is a lil more than usually what can it be, like a seal, thx for the help
Dave
Old Oct 7, 2008 | 02:59 PM
bL1Z's Avatar
Hey Dave,
I thought the same thing when I first test drove my 6MT. It feels a lot different from my 5MT-GSX. The Dealer said the amount of vibration was normal for my car however.
Maybe if you provide a detailed description of the vibration and during which driving conditions it occurs? Neutral, accelerating (speed/gears) and decelerating (speed/gears) could be potentially useful.
Also, have you noticed a change in vibration from when you first drove the car?
Old Oct 7, 2008 | 03:07 PM
Well i dont even have my linsense yet but, when i drove it a few times, it was vibration when driving not sitting in nuetral but when driving around
Old Oct 7, 2008 | 03:24 PM
Derzigster's Avatar
The shifter is mounted directly on top of the transmission. This is not a shift by wire and linkage design that isolates the shifter. There is going to be vibration in the shifter.
Old Oct 7, 2008 | 10:01 PM
G35JNKCV's Avatar
it seems like the vibration is a gear vibration, out of the transmission
after de-celeration of speed. vibration on shifter ***
Old Oct 7, 2008 | 10:51 PM
Mr.GEE's Avatar
20 Year Member
There is increased vibration of the shifter when using the engine for braking or sudden deceleration. As someone mentioned above, the shifter is directly connected to the gear shifting mechanism in the transmission, and during deceleration, there is contact in the opposite side of the gear teeth than when they are under accelerating power. Helical gears will be noisy and vibrate when the torque is in the opposite direction than normal. It's normal, don't be concerned.
Old Oct 7, 2008 | 10:56 PM
M.J.H.'s Avatar
Rwd.
Old Oct 7, 2008 | 11:49 PM
G35rails's Avatar
I was wondering the samething thank you for the help
Old Oct 7, 2008 | 11:52 PM
Beebo's Avatar
Its normal... its crazy when going up hill
Old Mar 21, 2012 | 05:41 PM
djamps's Avatar
It's the driveshaft. When the U-joints start wearing and develop play there will be some vibration at certain frequencies (speeds). Blip the throttle it goes away.. Confirmed with an Infiniti master tech. Not a serious issue just an annoying one.
Old Mar 21, 2012 | 06:04 PM
gary c's Avatar
Sure....^....he says the vibration is there at idle so the cars not moving, that's what I just read! I had two different cars that did the same thing, once I replaced the throwout bearings it disappeared. Kinda like some members here, they get old cranky and vibrate making noise....
Gary
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
5150DS
Sep 26, 2015 07:47 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
