rad fans not working
Old Oct 7, 2010 | 02:05 PM
gary c's Avatar
Even though your local Infiniti dealership is a POS you didn't need to spend that $125 since it's under warranty! Good recovery on your own though....
Gary
Old Aug 21, 2022 | 03:07 PM
foremanusa's Avatar
G35x awd
no fans
2006 G35, cooling fans not working, found 3 relays behind battery, which one is the high speed, I dont have a manual.
Old Aug 22, 2022 | 11:18 AM
2003G35stock's Avatar
G35 Manual
You can get a service manual here:
https://www.nicoclub.com/infiniti-service-manuals
Old Aug 23, 2022 | 09:19 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
It's sort of convoluted the way those relays work, if the first two are BOTH ON then it's low speed, if the second two are BOTH ON then it's high speed.
Just buy one relay to start with, write on it with a sharpie to identify NEW and the existing 1, 2, 3, put it in the lowest position to see if it turns on high speed (you can force the system to high speed by turning on the AC), if it doesn't then swap it for the other two positions. Then you can isolate the bad relay.
KevinnnVo
Oct 14, 2024 04:33 PM
champppy
Mar 31, 2020 12:25 PM
maximino
Aug 12, 2015 02:05 AM
yassy
Aug 3, 2015 12:24 AM
justgotg35
Jul 19, 2015 12:33 PM
