VDC, ABS, SLIP LIGHTS ON??
Old May 26, 2004 | 10:28 AM
2fast's Avatar
on my g35, my VDC, ABS, and SLIP light are all on...
I dont know whats wrong, it comes on and off ocassionally.. that cant be good.
How serious is this problem?
Old May 26, 2004 | 11:20 AM
Vic's Avatar
Vic
Re: VDC, ABS, SLIP LIGHTS ON??
last time I had fun in the parking lot.. buring tires and making donuts.. obviously I turned off my VDC..
after I did the first donut... why was the slip sign always on all the time? I turn the VDC button on and off, but the slip light was still there. I turned off the engin and turned it on again, then the slip light was off..
Anyone know why did the slip light was on all the time?
TB/Black, 6MT coupe, Aero, Premium, Navi, Pop Charger + Z-Tube, Clear Corners, 30% tint.
Old May 26, 2004 | 11:34 AM
hoshtaylor's Avatar
I've had this happen...took it to the dealer and it's not happened since...not sure exactly what the problem was...something to do with the wiring or a sensor...
"Operator, give me the number for 911!"
- Homer Simpson
Old May 26, 2004 | 11:45 AM
Merlin's Avatar
Staff ALUMNI
It's the Brake switch, take a look in the TSB board and you will find the info there. Delaer will just replace the switch.
Andrew, We Miss and Love You! Peace!
Old May 26, 2004 | 11:46 AM
ryoken's Avatar
Yeah, I had that problem too. Turned out to be low brake fluid. Even though it was above "min" in the reservoir, the sensor picked it up a low-fluid condition when it sloshed under hard cornering. Try filling up the brake fluid to the "max" line and see if it goes away.
Old May 26, 2004 | 06:38 PM
pjsg35's Avatar
brake sensor
Old May 26, 2004 | 07:38 PM
G35Girlie's Avatar
I had the problem...turned out that my front wheel bearing went...they replaced it and the problem is gone
2003 Brilliant Silver 6MT
Injen Intake
1/4 Mile:
60' - 2.425
1/8 - 9.482
1/4 - 14.511 @ 97.92mph
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
JermaineSanders
Aug 18, 2015 08:57 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
