My Gas Mileage....Is there a Problem? any suggestions would be greatly appreciated
when I called Mike at riverside our gas gauge normally whenever you hit E you will only fill up about 15-16 gallons...meaning that you have another 50-60 miles to go on your tank...the maximum I have gotten before was 240 with my new engine installed. I am thinking there may be alittle thing here and there that is causing it which is what I am having checked out..I am also running a walbro 255 Fuel pump in my car.
^ Does that Mike own a G? Does he driving days in and days out like most of us in here? Does he even fill the gas for us or he is just telling by the manual? I don't know about the later years, but 03 - 05 are known for fuel sender issue. Happened to me twice and had it fixed by the deal under the warranty. Happened again right when my warranty went out. I just leave it, only have to reset the trip meter everytime I fill her up and every 350 - 370 miles trip I fill up about 16 gallons. If your car still under warranty, have the dealer fix it for you. If not and you ***** out about that, you can try filling up the tank, reset the trip meter, have a reserve can of fuel in your trunk and drive til its empty out. See how much mileage you'll have in your tank.
http://x.infinitihelp.com/forum/show...gauge-731.html
There are some more info what the parts are in that site but I don't have tim e to search for you.
I usually shift at around 3500 rpms....sometimes will take it higher...but I normally go straight into 4th or 5th gear and just leave it. majority of my driving is typically on 121 and alittle bit of city driving...I only work 15-20 mins from the apartment..but I almost have to fill up every week or alittle more than a week.
#30
