Need Help With Winter Setup
Old Nov 21, 2008 | 11:02 PM
1ceman's Avatar
what winter setup is good for the snow on an 06 g35 coupe? and what size tire is good?
Old Nov 22, 2008 | 03:01 PM
yourdoinitwrong's Avatar
There are many, many threads on this. Do a search for winter tires and you can see all the comments people have on different setups. You need to make sure the overall diameter/circumference match what you are taking off so the VDC doesn't freak out. If you change the overall diameter/circumference then you need to keep the ratio front-to-rear somewhere in the range of no more than 5% difference to keep the VDC happy from what I have read. I have used Dunlop WinterSport M3's in the past and was very happy with them.
Marlin84
Apr 1, 2020 12:52 PM
DRG35R
Jan 31, 2016 07:14 AM
AL8782
Oct 3, 2015 10:26 AM
Patrick Bovee
Oct 1, 2015 10:42 AM
Learned Hand
Oct 1, 2015 09:02 AM
