steering wheel viberation before stop--guys help
Old Nov 26, 2008 | 01:34 AM
greek211's Avatar
hi guys,
My Baby G coupe ( 71000k) always have a steering wheel vibraton just before the stop. it gets worth when i turn on the auto A/C and the day gets cold. any suggestion guys
Old Nov 26, 2008 | 08:01 AM
OBG3506's Avatar
ok so you are saying that your steering wheel vibrates just before you stop and the vibrations get worst when the a/c is on auto and when the temperature gets colder. rotors maybe? does it do it all the time?
are you greek by birth or affiliation?
Old Nov 26, 2008 | 08:31 AM
vhtran's Avatar
^^^ bad rotors
Old Nov 26, 2008 | 08:51 AM
Chamoru671's Avatar
^^ rotors are warp
Old Nov 26, 2008 | 09:18 AM
wyldfyer's Avatar
"viberation". is that like "liberation"?LOL. Yeah it sounds like rotors...except I dont know how the AC would change things. When you arent driving and your rotor isnt hot, take your finger and rub it from the center up (both the inside and the outside). If it has grooves (kinda like a record, no pun intended) then it's your rotors. Good luck.
Old Nov 26, 2008 | 08:25 PM
grazsrootz's Avatar
yooo. warped rotors, nissan cars always have this i had a maxima for 3 years had the rotors replaced or ground down at least 3 or 4 times a year. also your engine prolly vibrates a lil more when the AC is on therefore you are getting two vibrations at once and it seems worse. i would say just keep the rotors until they get really bad thats what i started doing once i noticed my old 2003 maxima was gonna do this all the time
Old Nov 27, 2008 | 01:42 AM
greek211's Avatar
I actually changed my rotors(after market ) 20000k ago, but the problem still there.
Old Nov 27, 2008 | 11:41 AM
BolivianFuego's Avatar
They probably are warped, you probably braked to hard in rain or something causing them to warp.
There is shops that if you feel its worth it(still have enough meat on the rotor) you can have the rotor even'd out by a machine shop to stop that vibration, or you could just get new rotors.
Old Nov 27, 2008 | 07:58 PM
JZ39's Avatar
Alignment. Unevenly worn front tires will make noise and may cause vibration on stops and will likely do so more on cold days since the rubber is cold.
Old Nov 28, 2008 | 01:50 PM
Ginu's Avatar
I believe it would be a combination of alignment warped rotors and engine vibration.
The rotors can be machined fairly cheap (20$ or so) if you have the knowldege to take the rotors off (and enough meat to chew a bit out of them)
Alignment will run you around 100$ and also a huge factor would be the wheel balancing.
Not sure how much the wheel balancing would cost (assume somewhere in the 50$ range for all 4) but, for example my car eats front tires pretty fast. I assume the cambers need to be adjusted. During this process the tire wear is uneven so gets out of balance and at a certain speed (in your case slow speed) the tires get into a vibration; usually this happens at a little higher speeds 80-100 normally.
Also as someone else suggested while having ac on the engine could add to the vibration since of the engine placement.
jsimonk
Dec 22, 2023 03:49 PM
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
derres
Aug 28, 2015 03:27 PM
Karnicle
Jul 23, 2015 05:08 AM
