Problems Getting Gas Into The Coupe??
Old Jun 3, 2004 | 11:43 PM
DaBaur's Avatar
Someone else posting on this issue at one time on this or another G35 forum, so this may be a repeat. I spent 15 frustrating minutes at the gas pump today trying to fill up my coupe. When I pulled into the service station, I had just slightly less than a quarter tank of gas. So I was surprised when the pump shut off after only pumping 8 gallons. I tried repositioning the gas nozzle in just about every angle possible (without actually standing back 10 feet and aiming for the tank) without any success. I finally just gave up. It certainly wasn't any kind of defective gas pump nozzle: they are all pretty much standard. It was more like trapped air in the car's filler tube that prevented the gas from going into the tank. Has anyone else experienced this? Seems to me it could become an issue.
Old Jun 4, 2004 | 12:24 AM
xasnxkiddox's Avatar
Re: Problems Getting Gas Into The Coupe??
I had this problem occur to me when I helped my dad fill up gas on the coupe. The tank was only a 1/4 full and the pump stopped after 3 gallons. I was thinking maybe the pump was messed up so I just kept pumping some more manually instead of flicking that switch on the handle for it to pump automatically. I didn't think much of it until I saw this thread. Any others with this problem?
Old Jun 4, 2004 | 01:51 AM
Triji's Avatar
yeah,
It happened to me when I first got her, but it cleared itself up after about a week. Now just a couple days ago it shut off when I still had 1/4 tank left to fill. I knew I had more to go so I kept hitting the trigger and got a little bit of over spillage. When I started her up I still had 1/8 to go, even tho some poured out... not sure whats up with it, I have my 15,000 mile check up soon so I will have them check it out
2004 Coupe, 5AT, Twilight blue / Willow int, K&N Typhoon CAI, Hyper Grounding Kit, Mtek Xenon Fog/High, Clear corners, Hypers, 18's, Aero, tint, Premium, Val 1.
Old Jun 4, 2004 | 07:34 AM
Blitzjb's Avatar
It happens to me and I have almost 10K in the car... It seems not to happen if the car is off. Are you putting in premium? if not, perhaps the car is telling you something.......
04 G35C DG AT
Prem Aero Perf RSG CC
2004 Pathfinder for the family
Old Jun 4, 2004 | 08:21 AM
gto2050's Avatar
It did it back in the cold weather. Here in Joisey, they fill it for you. The Russian guy at the pump looked at me and said "No problem" and he turned the nozzle upside down and it filled up as normal.
Old Jun 4, 2004 | 08:43 AM
eiji14's Avatar
i had a problem this past weekend filling up at the sunoco that i always went to with my IS and never had a problem. there, the nozzles are enveloped in the black springy tubing and it wouldnt pump any gas in at all and after 3-4 tries at 2 different pumps i drove down to a shell where the pumps just have the bare metal nozzle and it worked fine.
i've filled up at mobil's too, their nozzles also dont have that rubber springy thing -- maybe that has something to do with it
Old Jun 4, 2004 | 08:48 AM
XCELR8's Avatar
Run a search..topics been discussed many many times
2003 BLK/BLK 6MT Injen clear corners Eibach Sways
My G on a photo shoot. More to come!
Old Jun 4, 2004 | 12:01 PM
Rever's Avatar
I went to my usual Mobil with 1/8 tank b4 going to Vegas a couple of weeks a go and the pump stopped after 5 gallons. My G has about 7K mi and this is the first time its happened to me. I stopped on the way to Vegas at another Mobil and it filled up just fine. A few days ago I went back to my usual Mobil (used a diff pump) and again it wouldn't fill up...only 6.6 gal.
What's going on????
04' G coupe/TB/Prem/Sport/Nav/35% Tint/Injen CAI/Clear corners/V5 Plenum
Plates: 1REVER1
Old Jun 4, 2004 | 01:48 PM
ironrice's Avatar
It happened to me once. Hasn't happened to me again but still concerns me. Glad that I'm not the only one.
Old Jun 4, 2004 | 02:00 PM
gsg's Avatar
gsg
The real point here is that this is a problem with the car and Infiniti should be contacted by all of us to demand a fix.
Yes it happens infrequently, probably only with certain gas pumps, and sometimes can be overcome by moving the nozzle around. But why should we have to deal with this?? I've never had this probelem with any other car I've owned and I'm sure I speak for all of us.
Doesn't Infiniti know how to make a gas tank properly?? To my knowledge Infiniti does not consider this a known problem as there is no TSB for it. Maybe the people that run this board could email all of the posts about this to Infiniti and demand a fix?.
Old Jun 4, 2004 | 02:29 PM
GR8TG35's Avatar
my car does the same thing occassionally, and it never moves the needle past the full mark on my guage.....
this just started to happen to me, so I figure there must be a valve or something in the filler neck that isn't working properly.......
Another thread a while back had a theory that the neck of the gas tank would cause a splash back effect on the nozzle, and shut it off way too early.....
Another thread said there was a TSB for a faulty valve that they would replace to eliminate the problem.....
so far my car just seems to stop short of full.....if it gets any worse I will have the dealership look at it.
04 cpe IP/willow/5at/prem/18's/JDM clear corners/Piaa's/MTEC H4 Super White fog/highs
Old Jun 4, 2004 | 02:31 PM
G35Rush's Avatar
gto2050: i'm not trying to be mean or anything but i'm sorry to say that no self-respecting jersey resident ever breathes (or types) the word "joisey" not once have i ever heard anyone from the best state pronounce it that way and i'd like to keep it that way if possible. thanks bud, have a good one, enjoy the clean air..
2004.5 G35 Coupe
5AT / Black on Black / Premium / Splash
soon: 35% tint, 4080's custom box, JL sub/amp (not sure which yet)
Old Jun 4, 2004 | 02:36 PM
b3ar's Avatar
I have this problem. I went ahead and took it to the dealer, the service manager said that there is no current fix for it right now, but it is because some gas stations (in my case Chevron) their pumps are not ventilated properly. And that causes for a mixture of air being pumped into our tanks.
Now I'm kind of stuck between a rock and a hard spot. My company pays for my gas on my Chevron card...but the service manager told me to try Shell. I guess I'll give it a shot once I empty my tank to see if that works better.
G35 coupe 6MT
Diamond Graphite/Graphite
Aero, Navi, Premium 5/15/03
Old Jun 4, 2004 | 02:48 PM
nate1749's Avatar
I always fill up at either BP or shell and have never had a problem. Also, always keep your car off when your pumping gas for those who don't already and when you close the cap make sure you hear it click close a few times.
