Move from East to West Coast 93 to 91 fuel, how???
Old Jun 8, 2004 | 06:28 PM
Fghtr112's Avatar
I'm being forced to move from the east coast to the west coast pretty soon. My coupe has about 8000 miles on it and has had 93 octane fuel for its whole life (about a year). Now I'm forced to head to an area that only has 91 octane as the highest grade. What should I do? or rather, what can I do? Siphon out the whole tank for a fresh start? Clean the injectors... oh what the he!!?
Old Jun 8, 2004 | 06:39 PM
Msedanman's Avatar
O.F. Administrator
Re: Move from East to West Coast 93 to 91 fuel, how???
Just switch to 91 octane. It's good gas, and what I use.
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old Jun 8, 2004 | 06:43 PM
3point5SE_Auto's Avatar
what is the altitude where you are moving? In my case at 5000 feet, I can't get the full benefits of 91 octane, so I only use it when I go down to the valley or other location lower like that.
Even 89 octane in the summer is overkill as there is not enough air to see the benefit.
check your altitude, if you are over 2-3000 feet, it may be overkill
anyhow, good luck on the move.
Better Life thru Chemistry
Black on Black 03.5 Sedan 6MT - Goodyear F1 GS-D3's 225/55/17, Custom Intake Tube, HyperGround Kit, Magnaflow resonator.
Old Jun 8, 2004 | 07:35 PM
chuckschilling's Avatar
If you're really that concerned about this, I suggest you buy a couple of 5 gallon gas cans from WalMart, then head to your municipal airport or air park and fill them up with 101 octane avgas. Add a couple of gallons of the avgas before you fill up with 91 and you should have ~= 93 octane in your tank.
Old Jun 8, 2004 | 08:09 PM
G35SanDiego's Avatar
You forgot to mention that the 91 will more than likely cost you more than the 93 you are buying right now hahahaha especially if you are moving to SoCal. Don't worry abou it, 2 octane units are not going to be noticable in an average car.
Old Jun 8, 2004 | 09:00 PM
DragonGcoupe's Avatar
Ehh.. All us SoCal people been runnin 91 all this time. You'll be fine. Except perhaps.. Your wallet .. Hahaha. I go to the same 76 for 91 octane at $2.45 / gallon. To me this is a steal. (This is northern OC.)
Black / Black 2004 GcoupeMT. Premium. Splash Guardz.
Old Jun 8, 2004 | 09:50 PM
TheDudeG4's Avatar
i just drove past the gas station, the local chevron is at $2.6599 / gal for 91, and I live in the valley (where it's cheaper)
I bet tomorrow the beverly hills chevron I drive past is at 2.6999
My Team Transport Profile
Old Jun 9, 2004 | 09:41 AM
Catatafish's Avatar
No no no!!! Do not use 100LL (low lead) fuel from an airport in your car. This fuel is designed for aircraft which uses piston engines (as opposed to Jet fuel). Even though it's called low lead, it has a ton of lead in it. This stuff is not good for your car. On top of that, it costs about $3-$4 a gallon.
This stuff will foul your plugs like no one's business and send your ECU into whack land.
2004.5 Coupe/5AT/Ivory/Everything but front spoiler/Nismo CAI/Crawford V5
Old Jun 9, 2004 | 09:43 AM
Catatafish's Avatar
If you have mods on your ride that may cause a lean condition (ie. pop charger and plenum, etc.) and don't have an ECU reflash, you may feel the pain. If you're already close to a lean condition, the 91 may be the last straw for you knock sensors. If you're not modded, or are managing your fuel condtion with a fuel management system of T/S ECU flash, you won't even notice. 91 is sufficient.
Old Jun 9, 2004 | 09:51 AM
StudlyMobile's Avatar
the sunoco by my house has 93 octane for 2.11 per gal
04 6mtC, DG - possibly most babied G on the board.
Old Jun 9, 2004 | 10:52 AM
Pratik's Avatar
Moderator
Thanks but you're probably in bumf*ck Montana :-) Here in D.C. I'm paying $2.40 for 93. Over $40 to fill her up.
Old Jun 9, 2004 | 01:55 PM
pratik97,
i guess central nj is considered bumf*ck montana to some :-)
nj has 2nd gas taxes in the country.... until our governor realizes.
Old Jun 9, 2004 | 02:46 PM
Pratik's Avatar
Moderator
Higher taxes but you boys don't even need to get out of your vehicles. That would def. come in handy in the winter :-)
'04 Coupe 5AT
D. Graphite/Graphite | Premium | Splash | Clears | Drilled Pedals | Z-Tube Waiting to be Installed
