Need Advice....
Need Advice....
I have a 2005 G35 Coupe AT, I am trying to build up my car but I dont know much about the possibilities. So far I have: Z-Tube, K&N Drop-In Filter, MD 5/16 ISO Plenum Spacer, GTM Valvebody Upgrade, Injen Track Ed. Exhaust, Stillen Grounding Wires, Strup Test Pipes, & Strup Headers are on the way.
Where should I go from here? I dont know what I should get next, I'm thinking a tune, possibly an EMS system. What do you guys think?
Once you get the headers installed you'll definitely need a tune, your
G will be running way to lean. I don't know what the valvebody upgrade is
but since you have an '05 with the REVUP motor why wouldn't you have gone
with MotorDynes MREV2 manifold?
Gary
Gary
6MT Coupe
I'd get a tune after your headers finally on with all your other breathing mods as suggested.
Valvebody upgrade probably could've not done b/c you're N/A and your tranny will never see madd hp/tq, but it's ready if you ever go FI.
Check out UpRev for tune. I have their Cipher so far and almost enough $ for their Osiris. That's who I'm going with on a tune.
05 5AT is a non-revup and is fine with just the 5/16th spacer.
05 6MT has the revup and yes that should run the MREV2 with spacer for most benefit for the revup only.
tune TUNE tune TUNE tune TUNE!!
I also highly reccomend the Central 20 3.9 gears with a Nismo LSD or the 350 EVO 3.9 gears..
the 4.083 gears arent even NISMO, they're just gears from a Nissan Frontier.
jnewk1981
Jan 28, 2013 01:54 AM
boostedforlife
Apr 15, 2010 11:41 PM
