Coilover question
Old Feb 9, 2009 | 04:11 PM
G35rails's Avatar
Coilover question
what is the best set of coilovers for a college budget?
Old Feb 9, 2009 | 04:15 PM
06g35meister's Avatar
BC racing.
Old Feb 9, 2009 | 05:13 PM
silverg35sport's Avatar
Originally Posted by 06g35meister
BC racing.
I second that statement
Old Feb 9, 2009 | 06:07 PM
gtrefever's Avatar
anything used really. i got my bc coilovers used look around, but if you want something brand new id say just go with megan or tein basics.
Old Feb 9, 2009 | 06:17 PM
Heinz's Avatar
When you install these coilovers, do you also have to install the camberkit, looks like the camber can be adjusted on top
Old Feb 9, 2009 | 06:18 PM
ShanesG's Avatar
Whats your college budget??? lol
you can get tein basics for <$650 and those would suffice!!!
Keep in mind camberkits if going lower than 1", alignment!!!
Old Feb 9, 2009 | 06:25 PM
ZeRo G35's Avatar
Just graduated from College - so i am kind on the same boat... just tagging this up to see what others say...
how much are camberkits?
thinking bout getting something lower than 1"... anything suggestions?
Old Feb 9, 2009 | 07:26 PM
eurodre's Avatar
sounds like u need 2 research some of the information that is here on this site
https://g35driver.com/forums/brakes-suspension-164/
https://g35driver.com/forums/suspension-fs-202/
https://g35driver.com/forums/suspension-225/
Old Feb 9, 2009 | 07:50 PM
gtrefever's Avatar
i dont think any of the coilovers for our cars come with the front camber adjustable plate that some coilovers for other cars come with. correct me if im wrong.
Old Feb 9, 2009 | 07:54 PM
eurodre's Avatar
well i read up on that and from what i memeba it would be pointless to have camber adjustable plates from what i read..
but yah correct no adjustable plates for camber
Old Feb 9, 2009 | 08:48 PM
SteveZ's Avatar
TEIN and others do for other cars, but that design is more along the lines of a car that would use Mac Struts otherwise. For our cars, adj camber is done with adjustable camber A-arms from Ichiba, Cusco, etc. They typically run anywhere from $280-400 a set.
You basically can get back to factory settings with lowering, otherwise they don't make sense. Camber plates with strut designs often make up for the lack of front suspension that tracks pretty well already, like ours.
Rear camber already plenty there and again unless lowering 1 inch plus, not much point and then just to avoid extreme camber. When I went to my current wheel setup, moving from a 245 on 8.5 inch rim to 275 on 9.5" rim, my effective camber in the rear was close to -2.5 deg. For better hookup I had it dialed back to ~-1.6 deg and went to zero toe rear for more predictable rotation (not everyone's preference, but with that much rubber oversteer isn't so much an issue).
Just make sure you get a quality alignment with any CO's or major tire size/width change.
Dunno if you can really see here but 275 is a good amount of tire, and with -2.5 deg the tires rode more on the inside.
Going for that JDM 'Ho understated NISMO Skyline look
Old Feb 9, 2009 | 08:56 PM
Beebo's Avatar
BC Racing
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
