Will these fit on our coupes?
Old Feb 18, 2009 | 12:28 PM
silentxnight's Avatar
Hey, so ive been looking for some rims for a while now. I search through the G marketplace everyday, but still haven't found anything to my liking. So i decided to check out the 350z marketplace. Lo and behold, i found exactly what i was looking for So..i was just wondering if these offsets would fit on a G since it was originally on a RX-8. Thanks in advance
specs are SSR SP1 19X10 +24 all around.
Old Feb 18, 2009 | 12:32 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
Yes, they'll fit. Might want some 15mm spacers for the rear though.
-GP-
Old Feb 18, 2009 | 12:33 PM
ttrank's Avatar
Grocery getter
^+1
Go for it!
Old Feb 18, 2009 | 12:40 PM
^^ Thanks guys..im waiting for his response on my offer. If he accepts, i will have these by tonight
btw i want these to sit flush with the car, so would the 15mm spacer be enough to do that? what about the front? thanks.
Old Feb 18, 2009 | 01:09 PM
aannddyy's Avatar
Yes those wheels are really nice, good offsets too.
Old Feb 18, 2009 | 02:03 PM
eurodre's Avatar
i hope for your sake that you have a pretty low drop if putting these on, any other kind of drop wud just make them look weird
Old Feb 18, 2009 | 02:06 PM
Do you want to run the same size tire all around? or are you going with staggered tires? How low is the car dropped? and do you have camber kits?
-GP-
Old Feb 18, 2009 | 02:12 PM
gary c's Avatar
They just might....!
Having a 10" rim on my front end might be a concern although they're only
1/2" wider than mine with similar offset. Think how nice they'll look on your
G when they're clean! Personally I wouldn't run a 245 on a 10" rim....dislike
the stretched look bigtime!
Gary
Old Feb 18, 2009 | 02:23 PM
Ghayes23's Avatar
They should fit great. You will want a spacer for the rear to sit flush, and you may have to try a couple different ones to find the exact fit you want. As far as tires, you should try running either a 255 or a 265 on the front and either the same size or something larger on the rear.
Old Feb 18, 2009 | 03:07 PM
-GP-
its not staggered. theyre 19x10 all around. im gonna be dropped on tein basics. with camber kits. will that work?
EnCr1pt3d
Jul 8, 2019 02:48 PM
teamghost
Jul 28, 2015 04:52 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
LoSt180
Jul 15, 2015 08:31 AM
