Need some specifics please..
Old Jun 21, 2004 | 10:17 AM
turbomaxima's Avatar
Man with green rock in Vortech
I have searched and looked around and can't find it anywhere.
Stock brembo rotor size? Is it 12.6" or 12.2" or something completely different?
I am trying to get a rotor upgrade made through www.fastbrakes.com for those of us with stock brembos. I am working on a 14.4" and 15.2" application. I didn't even think about the rears until now, but would probably like to have that done too.
I will possibly be sending my calipers and knuckles to fastbrakes to be the guinea pig, looking to see if there is interest too?
thanks.
jason
Old Jun 21, 2004 | 12:05 PM
Q45tech's Avatar
Re: Need some specifics please..
There is an optimum ratio of rotor thickness to rotor diameter [center of force application radius].
Larger diameter rotors without comensurate increase in thickness just decrease the brake pedal pressure required for same clamping force.
However much more they weigh does increase the thermal reserve but not nearly as much as thicker and larger combined.
A 15.2 vs a 12.6 would probably decrease pedal pressure by 15-20%...............32 vs 40 pounds of force. Might be good for weaker legged females. Even 80 vs 100 pounds at the limit [after fade].
After all if you turn ABS off even the stock brakes will lock the tire.
Let us know how much more the rotors will weigh [good thing] a few pounds each will lower pad/rotor temps by 10%.
Old Jun 21, 2004 | 01:55 PM
smaller rotors are optimum for things such as dyno tuning and 1/4 miles runs, or at least i am told.
i can't remember what my 10.8 vs 13.3 weighed on my maxima, besides the fact that it was DAMN heavy. i am not too concerned with overall brake pedal stiffness, as long as I am taking a little less heat away and getting a much better looking rotor
i will find out the specs on the upgraded stuff, but am i correct in saying the stock rotors are 12.6" in diameter and 1.25" in thickness? i don't have intentions on changing the thickness of the rotors, simply making them overall larger diameter (to fit in the stock brembo calipers).
Old Jun 21, 2004 | 07:46 PM
EverythingG35's Avatar
Brembo Rotors:
12.76" x 1.18" ventilated front rotors
13.07" x 0.87" ventilated rear rotors
Standard Brakes:
11.65" x 0.94" ventilated front rotors
11.50" x 0.63" ventilated rear rotors
Justin @
EverythingG35.com
1.888.216.5328
Old Jun 21, 2004 | 08:29 PM
Brembo Rotors:
<hr></blockquote>
That is exactly what I was looking for.
Thanks much.
jason
Old Jun 21, 2004 | 08:31 PM
Not a problem. I'm located pretty close to FastBrakes, so let me know if there's anything they need, I may be able to help them out as I have access to plenty of cars and parts.
Thanks!
Justin @
EverythingG35.com
1.888.216.5328
Old Jun 21, 2004 | 11:33 PM
al503's Avatar
those numbers are from the infiniti website but I believe they are wrong or just switched. The front rotor should be larger than the rears.
Old Jun 22, 2004 | 10:55 AM
Thanks!
<hr></blockquote>
I may take you up on that.. I would just tear my calipers and knuckles off for prototyping and r&d, but i'd rather not if i don't have to. Whenever I get a good chance to talk to brian from fastbrakes for awhile I will let you know.
And it did seem odd to me that the rear rotors were listed as larger, its probably the other way around.
jason
Old Jun 22, 2004 | 11:28 AM
The fronts aren't always a larger diameter, but they're usually a lot thicker. Early model G20's have a slightly larger diameter rear rotor as well, however the fronts are a lot thicker.
Caliper piston sizing and proportioning also play a factor in F/R bias, but most people don't ever go that in depth into their brake system either...
Justin @
EverythingG35.com
1.888.216.5328
Old Jun 22, 2004 | 11:41 AM
al503's Avatar
very good points but by my extremely unscientific method (took a ruler and measured the rotors by eyeballing it) the front rotors are slightly larger in diameter than the rears.
Old Jun 23, 2004 | 08:18 AM
Anyone have interest in this if I get it made?
Old Jun 25, 2004 | 07:28 AM
Talked to Brian last night and everything is a go. He is checking on 14"/15" rotors in the front, basically trying to figure out the hat configuration and ensure that the rotors he gets will not bring the caliper forward any, simply raise it up higher.
I also mentioned to him to try and do a rear upgrade as well. He has no issues with that, so will probably work that out after the fronts are done. There should be ample room to do a 15.6" rotor in front and a 14.4" in rear with 20" wheels (my own estimates of course).
I will keep anyone posted that is interested, so far this is the only rotor upgrade kit offered and should be priced pretty fairly.
jason
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
Cbohannan101
Sep 12, 2015 10:32 PM
