How does the painted surround around the key hole work?
Old Feb 23, 2009 | 01:43 PM
BolivianFuego's Avatar
Mine fell off, got my door fixed by a body shop. I try to push it back in place, but its loose. Do i need to get a new one? Is there something missing which keeps it in place?
Old Feb 23, 2009 | 01:47 PM
nghiars's Avatar
Do you mean the key hole cover? theres a tab behind it, check to see if thats been broken, if so you need a new one. Many members have popped them on but if you open your door, and look at the jam at the height level of your key hole, these a black plug, behind the plug is a bolt that holds the key hole in place, if you loosen it, you can put latch the key hole cover back on.
Old Feb 23, 2009 | 05:14 PM
I see... so to get it back on i most likely will have to loosen the lock and pop it back on, then re tighten?
arora_g35
Apr 16, 2026 02:52 PM
tal1412
Nov 28, 2022 09:25 AM
JMSABO
Aug 4, 2015 11:58 AM
newg37
Jul 26, 2015 09:32 AM
apintojr
Jul 23, 2015 10:52 AM
