I need Advice
Old Mar 7, 2009 | 08:58 PM
citymunky's Avatar
Question I need Advice
Ok here a quick run down. I have a 2005 G 6MT, and I have Oil Consumption. I wanted to built my block for FI, so I never worry about the consumption of oil, as I always changed my oil every 3K with AMSoil. Being that kids cost alot of money, my engine built is not going to happen anytime soon. So I deciced its time to car to the dealership to get a new motor. I spent last weekend removing all my Mod's (Painted Valve Covers, MREV2, 5/16" Spacer, K&N filter, Z-Tube, HFC's and UR Underdrive Pulleys set). After fighting with my valve covers gaskets to stay on, my friend who is a Nissan Tech disconnected my main engine hardnesses from almost everything and peeled it back so the valve covers could go on without the gaskets falling out. After all my stock parts were installed, I started the car and it sounded like a WRX/Sti. I was throw a DTC P0300 (engine misfire), and on my drive home I got P304 (misfire Cylinder 4). Over this past week I to everything I could think of to toubleshoot my problem. I replace the spark plugs, the swapped coil packs around, and I still got P0304. I did a engine compresstion test, all cylinders are well with limits. I didn't test the injectors, or do the injector clip node test because that's too much of a PITA, and I never touched them, so that should be covered under warranty if I have a problem.
Which bring me to my question, when I drop to the dealership, should act dumb or should I seem like I know what is going on. (I know not to tell about my toubleshooting) I'm asking because my dealership is a bit snobbish, and they feel OEM is best, if could have been made better Inifiniti would have put it there. I also can't go to other dealership because they are like 2 hours away.
Thanks for any advice.
Old Mar 7, 2009 | 09:28 PM
partyman66's Avatar
Reset your ECU. The car might be running poorly because the ECU has learned how to modulate fuel/air/timing characteristics based on the car with the mods installed. Now that you have the mods removed, it needs to start from ground zero.
Old Mar 7, 2009 | 09:51 PM
citymunky's Avatar
Thanks but that was the first think I did.
Old Mar 7, 2009 | 11:06 PM
gary c's Avatar
Stealership Visit....?
Try this....Golly I'm going thru oil like crazy and on the way down here it
started running terrible....what to do? Here's my warranty card, where's my
G37 loaner.... Just play the game....and Good Luck! Let us know how this turns out.
Gary
Old Mar 8, 2009 | 03:34 AM
Darkstar752's Avatar
Just play stupid bro. They have to give you a new engine anyway, so they probably won't even waste the time to fix it.
Old Mar 8, 2009 | 11:53 AM
citymunky's Avatar
Gary
Sounds like a plan.
Old Mar 8, 2009 | 12:08 PM
kernel's Avatar
SEC > Big 12
Gary
+1, just mention the problems you are having and let them do the diagnosis.
Fox843
Nov 7, 2015 05:43 PM
Rose M
Oct 12, 2015 10:00 AM
6spdGspot
Oct 5, 2015 01:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
