SES code! someone please help!
Old Apr 1, 2009 | 07:30 PM
Krispyklene's Avatar
i threw a p1283... i was wondering where exactly that is... i know it's sensor 1 or bank 2... but where is that sensor.... should it be replaced? or could something else be wrong? can anyone in socal help me out?
Old Apr 1, 2009 | 11:13 PM
bmason1031's Avatar
you running test pipes?
Old Apr 2, 2009 | 12:16 AM
ya for over 15k miles.... with no SES and i have non foulers... so i'm not sure that'd be the problem.
Old Apr 3, 2009 | 01:30 AM
mediabox's Avatar
http://www.nissanhelp.com/diy/obd_codes/p1283.htm
Sounds like an O2 sensor.... basically you are running lean.
Possible cause:
* Air fuel ratio (A/F) sensor 1 (the sensor itself could be bad)
* Air fuel ratio (A/F) sensor 1 heater (the sensor itself could be bad)
* Fuel pressure (not enough fuel pressure)
* Fuel injector (not enough fuel going into cylinder)
* Intake air leaks (too much air going in)
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
KallDay86
Jan 8, 2016 12:42 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
Detailed Image
Sep 28, 2015 07:04 AM
vamarris
Sep 26, 2015 12:56 PM
