Cannot get dealer to fix TSB issues on Coupe unless the TSB issue manifest itself. ??
Old Apr 16, 2009 | 04:34 PM
haagen_dazs's Avatar
I brought my newly acquired coupe (pics come later ) to the Infiniti - Herb Chambers.
I read on the forum that one should request for all TSB stuff to be fixed.
The service folks said that they cannot fix anything unless the problem arises that is. the TSB issue manifests itself...Then they would fix it
Are there any problematic issues with a 2006G35C?
They said that there was a recall for the headlamps for the 2006G35C so they are going to replace my headlamps for me.
I have no idea why there was a headlamp recall issue ...Anyone knows????????
Old Apr 16, 2009 | 06:29 PM
oh i read about the headlamps using the search function
haha
ok =)
https://g35driver.com/forums/g35-cou...djustment.html
Old Apr 16, 2009 | 06:39 PM
PAIXAO's Avatar
The only thing the dealership will replace on the spot like that is anything under a recall, like your headlights.
A TSB is more like a side note to the technician that lets them know about common issues with the car and how to fix it. They will fix them, as they stated, when the problem comes to light.
A faulty item or problem that has a TSB note with it will only be fixed for free if the vehicle is still covered under warranty, otherwise it will be an out of pocket expense.
A recall will always be replaced for free regardless of age and mileage of the vehicle.
Hope this helps you understand the difference between the two.
www.infinitihelp.com is a great website to check for recalls and TSBs.
Old Apr 17, 2009 | 10:41 AM
WTFisJUICE?'s Avatar
Im from the Boston area too. I just picked up my 04 G35C and was going to bring it into Herb Chambers to change fluids and etc.
I have a list of TSBs for them to look at, my car is out of warranty but has an extended warranty on it.
I hope I have better luck. I really dislike dealership mechanics though
slider_ua
Jul 29, 2015 04:17 PM
newg37
Jul 26, 2015 09:32 AM
itschuckster
Jul 25, 2015 08:07 AM
beevanhuynh
Jul 23, 2015 01:37 AM
