Car wont start! Alarm light stays on
Old Apr 28, 2009 | 10:09 PM
skandalous1's Avatar
Has anyone had this happen to them? I just had a motor swap done and the car wont start. When trying to start the car it turns but does not start. I noticed that the alarm light stays on. Could this mean that the immobilizer is activated? Will I need to reprogram the key to the immobilizer? Thanks in advance.
Old Apr 29, 2009 | 11:45 AM
RunLevelZero's Avatar
Valet mode
It sounds like you are in valet mode bud. My Viper on my G does that. Keeps the light on. I take it you have disarmed the car and it continues to stay on? Try removing the battery for a bit if you can not get it out of valet mode. It's just a guess on my part but could reset it. GL.
Old Apr 30, 2009 | 08:46 AM
falcor's Avatar
Are you reffering to a separate alarm light or the immobilized light on the driver's side dash?
Old Apr 30, 2009 | 09:01 AM
giddyup69's Avatar
looks like it could be a problem with the alarm.
Old Apr 30, 2009 | 02:27 PM
Light on the dash . There is no fuel supply nor spark. I am going to have the key reprogrammed again and see what happens.
Old Apr 30, 2009 | 03:07 PM
falcor's Avatar
is it an aftermarket key or oem
Old Apr 30, 2009 | 03:19 PM
OEM. The ECU and the battery were disconnected for about 3 months while I got everything I needed for the swap.
Old Apr 30, 2009 | 03:33 PM
falcor's Avatar
Ok.. Shouldn't be a problem then
Old Apr 30, 2009 | 08:56 PM
It must have been a battery issue because the car started with no issues today. Thanks for all the advice!
Mry
Mar 3, 2023 01:03 AM
mike730
Jan 12, 2018 04:25 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
Joshua615
Aug 31, 2015 12:29 AM
kenthung
Jul 21, 2015 05:56 AM
