limited/slip rear differencial?!?!?!
Old Jul 10, 2004 | 04:48 AM
hyescarface00's Avatar
what exactly is this? is it really necessary? why does only the performance wheel and tire package come with it? can i get it separate? does it have to do with the wheels or the actual tranny and/or suspension?
Old Jul 10, 2004 | 09:31 AM
Catatafish's Avatar
Re: limited/slip rear differencial?!?!?!
On the stock G the LSD option puts power to the rear wheel that is not spinning if the other is spinning. It is a viscous couple type which is nice but not as good as a mechanical LSD...it's not as instant. You may have heard the term "Posi traction" which is the Chevy version. The result, for all intents and purposes, is the same.
I won't buy a car without it. Better hook up off the line, more controlled cornering, particularly when you're flooring it, better performance in wet or slippery condtions, and it leaves 2 skid marks when you peel out instead of 1.
2004.5 Coupe/5AT/Ivory/Everything but front spoiler/Nismo CAI/Crawford V5/Crawford Cats/ Service Engine Soon
Old Jul 10, 2004 | 09:34 AM
dave's Avatar
Click here to learn about differentials.
<hr></blockquote> No, but it is helpful
<hr></blockquote> I'm pretty sure Infiniti only sells it as part of that package. But you can get an aftermarket one.
<hr></blockquote> It deals with the transfer of power from the transmission to the wheels
2004.5 DG/G 5AT Coupe with all options
Sidemarker turnsignal mod
GroundingGear™
2003 Yamaha YZF600R
Old Jul 10, 2004 | 11:07 AM
raysg35's Avatar
I'm doing the swap. It is a R-200V-LSD, you also have to change the half shafts, as they are different from those who have the standard R-200 diff., like me. If you want performance, like was stated, LSD is a must.
Old Jul 10, 2004 | 12:47 PM
Gsedan35's Avatar
I did the oem VLSD swap, with how much is cost's to do, it allows far too much slip before it locks to be remotely justified by it's costs. Viscous limit slips function by allowing slip to happen so that the fluid will turn into a solid, but while you wait for that to happen, you get way to much slipping. And even when it does finally manage to lock, if you've upgraded your tires, it's all to easy for the tires to win and shear past the viscous fluid. No other mod to date embarasses me more to admit I spend money on. And I only paid $100 for a new viscous core, (but $900 total as shown below).
$100 viscous core
$100 required LSD bearings and seals
$300 required LSD stub axles
$400 installation
____________________________
$900
For only $450 more I could have gotten a Nismo LSD and gotten a system that actually benefits the car when I NEED it to. And I don't track the car, just spirited street driving.
If your truely into performance, run don't walk away from doing the mod. Buy a clutch type LSD ( Nismo or one of the Cusco's specially designed to reduce clutch noise) or push for the Quiffe.
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old Jul 10, 2004 | 12:55 PM
esemes's Avatar
GSEDAN35-
thanks for being so honest, as painful as it was...
im thinking of the nismo unit for my coupe.... wonder if i should try to sell my oem unit?? (2k4½ coupe, 2K miles old)'
Old Jul 10, 2004 | 06:42 PM
bullseye's Avatar
Uh... That's QUAIFE, not Quiffe! :-))
An open differential sends power to the drive wheel with the least amount of traction. If you corner hard, and one of your drive wheels lifts off the ground, your stock diff sends all the power to the hovering wheel. An LSD sends power to the wheel with the most power. If you corner hard, and your inside wheel lifts off the ground, the LSD sends power to the outside wheel, the one with the most traction. An LSD can make quite a difference in the way your car powers out of a corner!
Look at a Quaife Automatic Torque Biasing (ATB) differential. The Quaife ATB doesn't use clutches, nor viscous fluid: It uses gears. It's bullet-proof, even in racing conditions. It has a forever guarantee, even under racing conditions, even if the unit is sold and re-sold umpteen times. I had one put on my '95 5mt Maxima SE, and it made a HUGE difference.
Quaife is just about the best differential money can buy, but... the last time I heard, they did not have one designed/ready for the G35 yet. Don't know where they are in development now, but plan to spend around $1,500 for their ATB... if they ever get them done and ready to ship.
'03 G35s 5AT, Garnet Fire/Willow
Staggered 18" SSR GT1/Bridgestone PP S03
Eibach Springs/Sways, Stillen 2-pc BBK
Stillen Intake & SS Cat-Back Dual Exhaust
Old Jul 10, 2004 | 09:16 PM
Tfasano's Avatar
Ever think that its going full throttle through the turn thats getting you pulled over and not your differential???
Luv My G
Old Jul 11, 2004 | 11:42 AM
Nismo_G35c's Avatar
Look like queef
|04'G35c 6mt| R.I.P 03'Is300 Boosted|
rezendvous420
May 31, 2020 01:26 PM
derres
Aug 28, 2015 03:27 PM
linedr89
Aug 17, 2015 05:11 PM
si_driver
Aug 11, 2015 07:08 AM
