Failed attempt on first oil change
Old Jul 12, 2004 | 02:10 PM
Catatafish's Avatar
Re: Failed attempt on first oil change
My only trip to my Infiniti dealer (Infiniti of Memphis) resulted in them trying to lose my valve stem cap, taking 4 hours to do a Consult reprogram on my key fob/lock unlock program, washing my car when I specifically told them not to, and when I did the pre drive off inspection found that they didn't even do the re-program. Then they asked me for $22 for a bottle of touch up paint. No way I'm ever taking it back there if I can do the maintenance myself. If it's less than a $200 warranty item, I'd rather drive 6 hours round trip and let Crawford handle it.
2004.5 Coupe/5AT/Ivory/Everything but front spoiler/Nismo CAI/Crawford V5/Crawford Cats
Old Jul 12, 2004 | 02:23 PM
Rocket65C's Avatar
I like the idea of homemade ramps with the 2x8's. I have been using my ATV wooden ramps that I put in front of the Rhino ramps and it works, but it is a PITA. I think I'll make my own ramps with the 2x8s. BTW, you can save money by doing your own oil change, but that's not why I do it myself. I use one qt of Mobil 1 and 4 qts of Mobil Drive Clean. It is less than $10 plus a couple of bucks for a filter. I like the convenience of doing it myself, making sure I use a copper crushable washer, and getting the plug back in properly. Also, I like knowing that I removed the plastic screws carefully and reinstalled them correctly.
Old Jul 12, 2004 | 02:34 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Catatafish...I agree 100%
The car jack should be for roadside emerg only.
There is no way I'm going under a car with one of those POS jacks holding it up.
<font color=blue>04 Silverstone G35, 5AT, Prem, Aero
ES100 225/45-18 front 245/40-18 rear
Borla TD, Z-tube, Eibach, 35%Tints</font color=blue>
Old Jul 12, 2004 | 04:40 PM
Gordgee's Avatar
Administrator
One of the locals used the OEM jack and had his coupe come crashing down on him! He had to call a towtruck to come jack the thing up off the ground so he could check it for damage and get the wheel back on. Definitely not a good idea to get under your car with the supplied jack!
<font color=blue>[i]GroundingGear™ Equipped </font color=blue>
Old Jul 12, 2004 | 10:36 PM
tpware's Avatar
you can take your front tires to 38 PSI and it will help you clear the Rhinos completely. you can still use some 3/4 MDF squares for that extra clearance. Just do not forget to take your PSI back down, as dont want to trash your tires.
Just curious about the "oil change pros" talk, I've talked to several GMs and SMs who freely admit that the lowest man on the totem pole does the oil changes. One told me its almost like punishment. I was also told its one of the few jobs for uncertified techs *and* they are under pressure to hurry.. Ummm, no thanks.
Old Jul 13, 2004 | 02:05 AM
xasnxkiddox's Avatar
Spending $45 was primarily for the ramps plus oil filter removal tool along with the 5 quarts of oil. The ramps and oil filter removal tool are definitely going to get its money worth in the long run because I can use the ramp for my other cars and continue changing my own oil.
Old Jul 13, 2004 | 04:19 PM
shodog's Avatar
On my sedan there is a bubble on the front cross member that fits my jack like a glove. I haven't changed my oil as while it is in warranty I will take it to either the dealer or an oil change place. I don't want to deal with any issues of proving an oil change was done.
I do however jack it up to take the plastic aerodynamic skid off. The oil change place I go to wants to charge an extra $15 to remove it and replace it.
Jim
'03.5 Sedan
Brilliant Silver/Graphite
6MT/ Premium package
Sport tuned suspension
Aerodynamic Body Kit
Navigation and Satellite Radio
Old Jul 13, 2004 | 11:48 PM
illphilly215's Avatar
When I did my 1st oil change... I noticed the dealership left out 4 bolts that places the aero kit. Most dealerships will skip cleaning afterwards...sometimes leave out other things like Catatafish mentioned. This is why I'll do my own oil changes. As for paying the dealerships $40 to get it done .. I could go with Mobile1 synthetic oil and Pure1 filter well under $40
03.5s/Brillant Silver/Premium/Sport/Winter Pkg<P ID="edit"><FONT class="small"><EM>Edited by illphilly215 on 07/13/04 09:04 PM.</EM></FONT></P>
derres
Aug 28, 2015 03:27 PM
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
