Technosquare ECU info plz..
Old Jul 13, 2004 | 08:16 PM
bolinp78's Avatar
Hi, I am looking for specific information on the technosquare ECU for my 5AT coupe.
How do i go about getting it installed once i have received it..
Does it do anything besides increase HP / torque and raise the stock rev limiter..
How much HP / torque does it add exactly?
Answers to any of these questions would be greatly appriciated , thanks.
Old Jul 13, 2004 | 08:23 PM
CHOI's Avatar
Re: Technosquare ECU info plz..
it also gives you smoother idle. scroll down and you will see the post "Any chips for the G yet?" read that it should be helpful.
Old Jul 13, 2004 | 11:07 PM
GZire's Avatar
Go to the G35 Sedan forum and check out the thread under TechnoSquare comments.
You need to pull your ECU and send it to TechnoSquare. Once they send it back you just reverse process to reinstall.
Horsepower and torque increases are probably not as much as you would think, but the shift pattern will change with an AT. More gains for AT than 6MT.
You can check out more at their website;
http://www.technosquareinc.com/index.html
One last thing, I am not sure if they've got the 2004 issues settled yet (2003 model cars are OK), so you need to check your ECU to make sure they are able to mod it.
Hope this helps.
Old Jul 13, 2004 | 11:45 PM
CHOI's Avatar
yea, the 2004 is not out yet. check the website and call them.
06g35
Feb 14, 2022 05:59 AM
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
Rose M
Oct 12, 2015 10:00 AM
TurTLe*
Sep 29, 2015 01:43 PM
