Locked myself out of my car. How do i open the car with the valet key?
Old May 22, 2009 | 01:27 PM
dev1983's Avatar
^thats strange, my 03 has a key hole there
Old May 22, 2009 | 01:30 PM
frozenmango's Avatar
Originally Posted by jibberjabbers
Dude, every G came with 2 remotes. And no, I don't see a keyhole on your G. Your G has been thru war though. LOL all those nicks and paint chips.
But yes, you could have gotten in thru the rear trunk.
Anyways, the previous owner probably did something to it.
unfortunately mine did not come with an extra fob as the first owner lost it. the nicks and dents were courtesy of the previous owner as well =T
Please elaborate more on the trunk
Old May 22, 2009 | 01:31 PM
RST531's Avatar
how can you get in thru the trunk? there is no key hole or button back there on the 04's coupes.
jibberjabbers's Avatar
my bad i thought our trunks had a key hole. Epic fail
Old May 22, 2009 | 01:40 PM
redlude97's Avatar
when you replace the escutcheon, you have the option of completely removing the key cylinder and replacing it with a blank, which appears to be the case here. Prevents thieves from breaking in, but then you aren't left with an option when you lock yourself out like here.
Old May 22, 2009 | 01:41 PM
9600baud's Avatar
Your keyhole is behind that metal thing. You didnt remove the full escucheon, just the painted plastic cap of it, or so it looks like...
Old May 22, 2009 | 01:42 PM
if you were right about the trunk i'd shoot myself lol
btw, i woke up today expecting to see my windows looking like it got in a fight with a cat only to find 2 small scratches so i guess my windows won haha wut a night.
Old May 22, 2009 | 02:35 PM
redlude97's Avatar
This is what it should look like under the cover if you have the key cynlinder still there
Old May 22, 2009 | 03:28 PM
well no shyt guy
Old May 22, 2009 | 03:56 PM
redlude97's Avatar
well no shyt guy
Not so obvious to this guy
Old May 22, 2009 | 04:09 PM
well no shyt guy
Maybe you have a black plate that is covering the key hole? Can you check and see if you can remove it?
Old May 22, 2009 | 04:33 PM
nope, that thing is one solid piece.`ahhh unfortunates like myself just have to be extra careful.
Old May 22, 2009 | 05:23 PM
partyman66's Avatar
It would also suck if your car battery died while the car was parked or if your keyfob battery was weak and completely died while you were out at a store with it parked in the lot. This type of no-keyhole setup wouldn't work out for me too good because I winterize and store my car for the winter without the battery in it. The only way I can get into my car after the winter is to use the key to manually open the drivers side door.
Old May 22, 2009 | 06:08 PM
t7n7's Avatar
Originally Posted by Marlin
I know. I stated that I used my key to roll up the windows, since the key fob for whatever reason, does not roll up the windows when you hold the lock key. Ah, that doesn't make sense.
its for safety reasons, in case you are not paying attention to the car and rolling up the window while someone's bodyparts are in the way...
and believe me... as much as we have pinch protection, the windows can really **** up your body parts until it decides to 'stop'. thats why they want you to be there holding your key like a 90's car and watch teh windows roll up.
dealer info*
Old May 22, 2009 | 06:15 PM
  #30
t7n7's Avatar
holy ****... a true keyless entry system lol....
