which ecu upgrade is better osiris or.....
Old Jun 29, 2009 | 11:53 AM
seymore4's Avatar
m56
Originally Posted by stclairwest
Can you use osiris for any year g35? I heard cobb doesnt work with early 03-04 models?
I think it doesn't work with the early 03 models. Not 100% tho.
Everyone else should be good
Old Jun 29, 2009 | 11:58 AM
06g35meister's Avatar
I have osiris and LOVE it. my maps:
1) 93 performance (for TX)
2) 91 performance (for KS)
3) 100 Shot Nitrous (3300-6600)
4) Economy Tune (4500 rpm, 13.5 afr)
5) Valet (35mph, 3500 rpm)
Old Jun 29, 2009 | 12:38 PM
HarrisonK's Avatar
You should take out your ECU yourself, you can find a DIY on AlteredAtmosphere.com, send it to them and have them give you a tune. They do the best work, IMO.
Old Jun 29, 2009 | 02:51 PM
tblazing's Avatar
Originally Posted by seymore4
Yes everything works just like before.
To change maps you hold down the cruise button and press the cancel button 1-5 times depending on which map you want. Once you release the cruise button the set light blinks the corresponding number of times. Easy as pie. Its up to you to remember which map is which number tho.
so if you on map 2 and the set light blinks 5 times are you on map 5 or 1?
Old Jun 29, 2009 | 04:01 PM
dofu's Avatar
20 Year Member
Wow... did they sell you or what? Since every car is different, no preprogrammed reflash can match a good dyno tune with the car physically on the dyno. They can get the tune down over time, if you keep sending them your ecu over and over again, if you have data logging. Otherwise, the tune you get from them is just a guess or an estimate, and will not be 100% accurate.
Old Jun 29, 2009 | 08:50 PM
seymore4's Avatar
m56
For real. I don't care how good their system is, the specs and tolerances are different on every single motor and nothing can beat what you get when you put it on the dyno with a knowledgeable tuner. A preprogrammed tune is by far better than stock, but not optimal for YOUR ride
Old Jun 29, 2009 | 08:52 PM
seymore4's Avatar
m56
One push and one blink for map one. Two pushes and two blinks for map two. Three pushes and three blinks for map three....
It doesn't matter what it was on before, it starts over each time you set it.
KruZZe
Feb 27, 2023 05:04 PM
g.spot
May 9, 2016 10:54 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
NyCrAzY
Oct 1, 2015 09:19 AM
