engine air filter, drive belts
Old Jun 15, 2009 | 03:02 PM
brooklynite's Avatar
just came back from the dealer and they said that my air filter and drive belts need to be replaced. quoted me $290.00 for the job. i told them not at this time since i wanted to see my options.
instead of simply buying a new oem air filter and oem drive belts to replace, wouldn't it be better to get a z-tube w/ jwt pop charger to upgrade the air filter issue?
as for the drive belts, wouldn't it be better to just get a set of unorthodox pulleys w/ belts to upgrade the older drive belts?
i'm not sure if the increase in $ to replace/upgrade the parts are worth it. i believe the ztube and pop charger is, but not sure if the pulleys will make that much of a diff over simply getting just new belts. any comments?
Old Jun 15, 2009 | 03:05 PM
LjN_728's Avatar
Or you could take it to an independent mechanic. I remember my drive belts were $70 OTD and the air filter around $17.
Old Jun 15, 2009 | 03:26 PM
mnrg35's Avatar
the dealer will try to take of all your arms and legs if they could. i would say get the belts done by a mechanic like LjN 728 said unless you are planning to get the pulley later in life and if you do why not just get them now. for in the intake that is a must insted of replacing the filter. but i would say go with CAI since the objective is to try and get cold air into your engine insted of getting the warm one that your engine is throwing out but then again that is just my thoughts. after all it is your choice
Old Jun 17, 2009 | 10:34 PM
BloodlineG's Avatar
Just go to nissan buy the drive belts put them in yourself its cheap. And there's prob a diy on here somewhere for it.
Old Jun 17, 2009 | 10:44 PM
bocatrip's Avatar
Independent shops around here charge around $140 for all the belts to be replaced.
Old Jun 18, 2009 | 01:26 PM
LightsOut's Avatar
SIETESG
just change out your oem filter only.. Your airbox is better than any aftermarket intake out there.
as for the belts just take it to a local mechanic
Old Jun 18, 2009 | 01:48 PM
jutn35's Avatar
G35 Coupe
HA ! i bought both my belts for 40$ at concept Z and my filter for 11 bucks from kragen which is just the same as OEM but looks better too, and replaced them myself, f*cking dealership, they make me laugh.
Old Jun 18, 2009 | 02:28 PM
IPGSEDAN's Avatar
How hard was it to replace the belts, did you need to take off the bumper?
dealer quoted me 250 for this, lol i almost laughed in their face
Old Jun 18, 2009 | 03:15 PM
eurodre's Avatar
^^well you know its a lot of work.. taking off the bumper, scratching ur ***, fondling your *****, picking your nose and then putting on a belt.. duuuh
Old Jun 18, 2009 | 03:18 PM
GMoNeYAir23's Avatar
Its not hard to replace the belts at all..took about 30 mins, and thats because you have to take off the bottom sheild. You don't have to take the front bumper off. Just do it from underneath the car.
Old Jun 18, 2009 | 03:19 PM
IPGSEDAN's Avatar
^^^ taking off the bumper is a piece of cake, i know that, i meant replacing the actual belts. if you would be able to acces them by just taking off the bumper and if there was anything i needed to know that will help me in installing the new belts.
Old Jun 18, 2009 | 03:22 PM
IPGSEDAN's Avatar
oh ok, ill try that method, did you come across the problem with the belts making a squeeling noise st start-up? I read that this is caused when the belts are too lose or too tight.
Old Jun 18, 2009 | 03:24 PM
I did, thats why I replaced them..they were all cracked too, so I figured with 80,000 miles on my car it wouldn't hurt.
Old Jun 18, 2009 | 03:26 PM
IPGSEDAN's Avatar
were and for how much did you get them for? did you get an OEM replcement or upgraded to another brand? thanks
Old Jun 18, 2009 | 03:27 PM
eurodre's Avatar
lol guys im kidding, im sure its pretty easy
