How to fix slight dent in rear bumper
Old Jun 17, 2009 | 01:19 AM
Vblick's Avatar
Guys,
I've been reading of ways to fix normal dents on this site. However, I have more of crease/faint dent on the rear bumper that is about 2 inches long. You can only see it at certain angles but it's driving me crazy. Techniques i've come across for dents vary from blow dryer to boiling water. I can reach the back of the crease from the license plate area. Will heating it up and pushing on it from the back of the rear bumper do the trick? On another forum someone told someone else that they should pour boiling water on it and it would push itself out. What do you guys think?
Old Jun 19, 2009 | 10:15 AM
Vblick's Avatar
.:bump:.
no one?
Old Jun 19, 2009 | 10:42 AM
maybe u can push it out from inside, ? my friend tried that on his corolla and it worked, i have a small on in my driver fender, some stupid apartment gate closed on me while i was texting :/
Old Jun 19, 2009 | 11:45 AM
9600baud's Avatar
try the heat w/ blow dryer / compressed air method. If that doesnt work, you're SOL
Old Jun 19, 2009 | 03:20 PM
LEE13's Avatar
I had this happen once, a soft dent where paint was not scratched and did not break the surface of the paint. I removed the whole bumper cover and took a heat gun to the area. Once the area is warm enough you can push out the ding by going slowly and taking your time. Just where gloves to push out the dent and you'll be able to feel the surface smooth out. A blow dryer will do the same just not as much immediate heat which is a good thing if you're unsure about getting to0 close and melting plastic or burning yourself. There are a few posts about removing the bumper cover, just remove the clips around the trunk and remove the taillights.
Old Jun 19, 2009 | 03:25 PM
Black_Attack's Avatar
but taking off the bumper is a pain in the @$$
Old Jun 19, 2009 | 03:57 PM
0MGHI2U's Avatar
i had a huge dent on the corner of my bumper cuz some A HOLE hit me and took off... i took a heat gun and popped it right out.. just gotta get it painted.... taking the bumper off is easy
Old Jun 19, 2009 | 09:39 PM
bocatrip's Avatar
Anything other than replacing the bumper and doing a repaint is not going to be a quality job. Considering you will need to remove the bumper to try and heat and pop it out, you might as well just bite the bullet and replace the bumper. Our cars have not reached the $5,000 value range where it's just as well we do an improvised job to get by. The entire job is not all that expensive anyway.
tiguy99
Mar 1, 2016 11:42 AM
st33zygill
Jul 29, 2015 10:05 PM
T.Y.M1210
Jul 29, 2015 11:53 AM
