Drivers side power window not functioning
Old Aug 9, 2009 | 12:32 PM
pythonjosh's Avatar
Its the motor. I got mine replaced and never had a problem since.
Then it started happening to my driver side window.
Old Aug 9, 2009 | 01:01 PM
obex26's Avatar
Well what doesn't make sense to me is the fact that it still adjusts now that I have the window in the up position. I can push on the relay tab in the driver quarter panel and it will push the window the quarter inch up and if I release it will lower it back down the quarter inch. A couple of times I have closed the door since friday and it has not gone back up the quarter inch so I try the trick of holding the switch in the up position and closing the door and it goes back up to seal the window again.
So if it were the motor would it not be functioning at all? I of course have not tried lowering the window yet because I have not been to the stealership as of yet.
Old Aug 9, 2009 | 01:15 PM
Deezflip's Avatar
My driver side window motor took a crap yesterday so I decided to take the door apart and take a look at the motor.
I was in the process of removing the motor in plans of replacing it, I even tried the reset button but no luck. I decided to take a look at this section as shown here...
I unscrewed the three screws(only two is shown on this pic), after rmoving that metal cover off(this will expose the motor's internals), I noticed that there were a huge amount of carbon build up all around(not to mention I smelled this burning smell for the past couple of days). I gave it a little blow(no homo) and carbon dust just went all over the place. I suggest using a can of compressed air or something.
I assembled everything back together and WALA...it worked! I was surprised myself on this one. I thought i was going to need a replacement motor. Don't mind the ten million bolts you'll have to remove to get to the motor though. These motor assemblies are good at keeping a water-tight seal but at same time, terrible for venting out excessive carbon dust. Even if you have one replaced, it might fail once again in a couple years.
Old Aug 10, 2009 | 12:38 AM
twalls's Avatar
CLUB MODERATOR
That is the issue w/ the Nissan window motors.. This is was a faulty design.. The 350z windows have the same problem.. They didn't build the motors w/ vents in them to displace the carbon fillings.. After a while, you'll have to do this again.. Doesn't matter if you buy a new motor, it'll eventually happen to that one too.. I've heard of people on their 3rd or 4th motor on BOTH doors.. Just a faulty design.. Opening the door, removing the motor, and cleaning it is the only way to fix this.. Had the same problem w/ my driver side window..
Old Aug 10, 2009 | 12:40 AM
sicknasty072's Avatar
same thing happened to me. took it to an infiniti dealership and they had it fixed no cost to me in under 2 hours. it was under warranty
Old Aug 19, 2009 | 02:36 AM
WhosRich's Avatar
My passenger side just crapper out. Good thing that trick worked or else I was going to have to sleep in the car. Going to the dealer tomorrow.
Old Aug 19, 2009 | 01:04 PM
BloodlineG's Avatar
yea ive already replaced both motors and my passanger side regulator.
mbe093
Lights
Oct 2, 2016 11:09 PM
Ludz
Lights
Mar 28, 2016 02:06 AM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
vstypicals
Jul 20, 2015 10:55 PM
