Drivers side power window not functioning
Old Jul 8, 2009 | 11:03 PM
bcgreen's Avatar
I rolled down my window (drivers side) and the darn window won't roll back up. The passenger side is okay. Even after playing around with the switch the window won't move. Does anyone have any ideas on how to figure out if its a motor problem or fuse problem?
Thanks,
BC Green
Old Jul 9, 2009 | 07:18 PM
Heero's Avatar
Your motor is most likely dead. Buy a lifetime guarantee one at Kragens and replace it yourself.
Bang on your door frame while pushing the "up" button at the same time. That should roll your window back up for now.
I know because I had to replace both of mine.
Old Jul 9, 2009 | 07:53 PM
nghiars's Avatar
Yep.. both of mine went our but fortunately for me, I was under warranty.. Just waiting for these to go out so I can replace with aftermarket parts.
Old Jul 10, 2009 | 06:30 AM
Heero's Avatar
I'm not sure if they sell aftermarket window motors anywhere? The ones I looked at have always been refurbished window motors.
Old Jul 10, 2009 | 01:19 PM
pythonjosh's Avatar
The trick I've been told here that has worked for both my motors now is this:
Open the door, hold the switch in the direction you want, close the door while holding the switch. If that doesn't work, gotta open up the door panel and raise the window manually.
Old Jul 10, 2009 | 03:08 PM
bocatrip's Avatar
Window motor failures are quite common on our cars. There are no real shortcuts other than replacement of motor. Best bet is to shop around for independent shop quotes for replacement of motor. Good luck.
Old Jul 11, 2009 | 02:36 AM
bcgreen's Avatar
Well, I spent 6 hours taking the drivers door apart and trying to put it back together again. Finally just after midnight I buttoned it up. The motor square piece won't fit into the bracket. It was just slightly off so that I couldn't be the screw holes to line up with the bracket. So I took the motor cover off to move the square center just enough so it would fit. The problem arose when the cover to the motor didn't completely seal. So I screwed it back together the best I could and reassembled the door. When I flipped the switch, the motor was silent but the switch does make a small noise. The noise is not that unusual, its a typical relay sound and it was present when the window stopped functioning. The passenger door switch does not make any sound comparable to the drivers door.
So do you guys think its the switch or the motor?
Old Jul 11, 2009 | 03:29 AM
boz35coupe's Avatar
i just got the same problem... my date rolled the window down and couldn't roll it back up. i got out and tried rolling it up by turning the key in the door, and it worked.
anyone know why it would work like that, but not with the switch?
mine was the passenger window btw.
Old Jul 11, 2009 | 04:00 AM
pythonjosh's Avatar
@bcgreen
The motor is easy to diagnose if you have the door apart. Get a hot wire tester. There's only 2 wires going to the motor, and they alternate polarity. Going up, one wire is hot, going down, the other wire is hot. Vice versa for ground. So if the wires alternate hot and ground to the motor, and it doesn't work, it's the motor. If the wires don't alternate the polarity, then it may be a relay problem, or the switch, or any part of the circuit between the switch and the motor.
-Josh
Old Jul 11, 2009 | 07:24 AM
PPGFREAK's Avatar
^+1 Good post my friend But yes find out what it is before you start buying parts. I think I have both if you find your self in a bad spot.
Old Jul 11, 2009 | 12:45 PM
bcgreen's Avatar
Originally Posted by pythonjosh
@bcgreen
-Josh
Josh, can I test out the motor by just hooking it up to the switch and turning it on? If it works in my hand then I can go ahead an reinstall it or am I going to have a problem doing it this way?. I don't know if I screwed things up by not being able to put the lid back on the motor tightly, but I guess I can go and get another and just tell them this one didn't work. I can take the switch out and have someone do a quick test and they can tell me if I have a bad switch
Since I have taken the whole door apart and reinstalled everything, this time it should go much faster.
Old Jul 11, 2009 | 02:39 PM
boz35coupe's Avatar
im an idiot.... haha i accidentally pressed the window lock :/ and realized when woke up this morning
Old Jul 11, 2009 | 03:40 PM
pythonjosh's Avatar
The wires only have power, either direction, when the switch is up or down.
If the motor does spin in your hand, then everything electrical is A OK. That square plastic piece that the motor fits into Can possibly get chewed up. That's what happened to me last time, after replacing the motor, but the mechanic got it working for me for free. Haven't had any problems since. But yea if the square **** is spinning when you flip the switch, everything electrical is good.
Old Jul 11, 2009 | 03:44 PM
pythonjosh's Avatar
You can take out your switch and plug in someone else's. But the switch itself is rarely the problem. Which happened to me in my last car. I had to jerry rig a 3 channel switch to make it work without replacing the switch. But the motor is usually the problem with our cars, not to say that something else may be the problem.
Old Aug 7, 2009 | 08:49 PM
obex26's Avatar
I just tried this trick I am having the same issue. It worked but now I have to ask is it the motor or the switch. I also tried to use a switch from another G35 and it did not roll up my window. So is it in the wiring or the motor is on its last crank so to speak?
And thanks for the tip...
