k&n air filter re-oiling - how long to wait on oil to dry before I can install agian?
Hey all,
I cleaned my k&n panel filter, and oiled it this evening approximately 3 hours ago. How long should I wait for the filter to dry before I can reinstall? K&N's site is saying only 1 hour, but that seems too quick.
thanks
thanks
Your three hour duration is plenty of time. I usually clean mine on a sunny day so I can let it soak up some rays for an hour or so while I'm doing other stuff before reinstalling it. It really doesnt require too much of the oil to function properly.
If you think you over-oiled it, of course let it sit a little longer.
Depends on the ambient temp and humidity, but to be safe I would leave it for about 24 hours after the rinse. I left it over night after oiling before reinstallation.
allowing it to fully dry after rinsing it is the most important part. If it is still wet when you reoil the oil wont soak into the element, it will just sit on top.
If it is dry the oil soaks right in and can be installed almost immediatly.
vstypicals
Jul 20, 2015 10:55 PM
