next step after POWER
Old Aug 11, 2009 | 09:54 PM
shafferjohn92's Avatar
ive got all the power upgrades so far that i would like, now time for the handling part of the car. any where i can start? coils of course.. then from there where should i go.
Old Aug 11, 2009 | 10:07 PM
drifts500's Avatar
Sway bars definately and coils.
Old Aug 11, 2009 | 10:10 PM
Agent F's Avatar
stillen adjustable sways, coilovers and a rollcage!!!
Old Aug 11, 2009 | 10:21 PM
SDGeneralCounsel's Avatar
No rollcage what so ever unless you car is exclusively a track car. Rollcages are far too dangerous for everyday driving and frankly if you have a roll cage, your car should be fully gutted and weight stripped. Otherwise, what's the point?
Old Aug 12, 2009 | 12:45 AM
jookyshank's Avatar
I haz hugz to givez
I've had a DD with a cage and i'll tell you it's just a pain in the ****! I'd skip it unless you're planning on some serious track time. (or you wanna run sub 11 second 1/4's)
Sways are nice, and as always with good coil drop, you probably wanna pick up camber kits to tame the angle, too much camber can hinder yer handlin.
Anyone had experience with the chasis brace (the big ol thing) looks kind of promising.
+sizin rims can help out just find that balance between sidewall and back pain
Strut Tower braces i'm sure help a bit, but they look boss (Like Poly Bleaker)
if you wanna go full on fast stuff, poly bushings will stiffen things up suspension at the sacrifice of comfort and sound (they squeek) Maybe the stillen engine brace...haven't tried that one either but the theory sounds solid. (see what I did there)
What else gang?
Old Aug 12, 2009 | 09:37 AM
ish83's Avatar
From what I have read, sway bars with adjustable endlinks would be the best upgrade for your suspension after coilovers.
Old Aug 12, 2009 | 11:25 AM
Cloud_35's Avatar
The point of a roll cage is to protect from roll over, chassis stiffening, and overall safety. I've seen plenty of cars with roll cages and full interiors, albeit, not a full cage, more like a 6 point cage. Please explain how a product designed for overall safety is dangerous in a daily driver, or any kind of car for that matter.
Old Aug 12, 2009 | 11:46 AM
Ace198920's Avatar
I would definitely say Coilovers. But what kind though? Anyone have opinions?
Old Aug 12, 2009 | 12:25 PM
Sinister350GT's Avatar
I went with TIEN Springs and KYB Shocks
Sways, all the GT Chassis Braces.
My car drives like it on rails. Even the shop out here says its the tightest car they have put together in the turns.
Old Aug 12, 2009 | 12:32 PM
drifts500's Avatar
I have oem sports struts and 350z s-tech + Hotchkis sways (med/med). Its kindda soft when drive hard.
Old Aug 12, 2009 | 12:35 PM
LightsOut's Avatar
SIETESG
sways
- springs/coils -
strut bar
is all you need.
Old Aug 12, 2009 | 11:39 PM
jookyshank's Avatar
I haz hugz to givez
The full roll cage was intended for use with a helmet/hans/harness system. If you are running all these devices, then yes, the roll cage adds amazing ridgidity and of course safety. These were basically intended for racing with a safety system, not as a stand alone chasis stiffener. If you are allowed to bounce off the cage, as you may in a heavy impact with just a standard safety belt, it will cause far more damage to your body than the softer interior of a passenger car, which has been engineered for maximum safety within reason. This is how a cage can be more detrimental in an impact than a "stock" interior.
As I mentioned earlier, I had a full on custom cage in my highschool hot rod. And other than the pain in the **** of getting in and out around the cage...not to mention losing the back seat in all realistic terms, i had quite a few friends bang against the cage in hard cornering, dumb driving, etc. And I can have any number of them tell you, cages without harness/helmets...suck.
Old Aug 13, 2009 | 03:54 PM
t7n7's Avatar
^+1.. well said
Old Aug 13, 2009 | 05:55 PM
potmilkz's Avatar
^ +2.. the bars inside the cars can hurt you or other people.. imagin banging your head against a steel pipe..
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
wow600rr
Sep 28, 2015 11:50 AM
vamarris
Sep 26, 2015 12:56 PM
