low beam is out... HELP
Old Sep 8, 2009 | 11:41 AM
Gspotsilver35's Avatar
I went to autozone to get a replacement bulb because my passenger side bulb was turning purpleish? I figured it was going out because its never looked that way. After looking at autozone I couldn't find a HID bulb. I have an 04 (non-projectors)... Also my high beams look more yellowish is this normal? What bulb can I replace those with? I want the low and high beams to match...
What bulb do I need? I didn't think I had to go to the dealer to get a replacement... Help. Thanks in advance...
Old Sep 8, 2009 | 04:28 PM
code2424's Avatar
It's not like you use high beams so y worry? Everryone has yellow light as a high beam. If you put HID bulbs without a ballast they will most likely burn out fast. And look on ebay they have alot of HIDS
Old Sep 8, 2009 | 04:30 PM
LjN_728's Avatar
2004 INFINITI G35 (With HID (high intensity discharge) headlamps)
Low beam headlamp
HID-D2R
High beam headlamp
9003/HB2
9003SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9003ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9003EB EcoBright - Your Environmental Choice
9003XV XtraVision Halogen - The Brighter Light
9003CB Cool Blue Halogen - The Whiter Light
Old Sep 8, 2009 | 04:53 PM
LightsOut's Avatar
SIETESG
I have bright white fog lights FS if you like 15 shipped.
you need a d2r hid bulbs 4300k for oem replacment or if you want bluish tint 6k and up
Old Sep 8, 2009 | 05:58 PM
ZeRo G35's Avatar
what matches best with the highbeam/lowbeam?
Old Sep 8, 2009 | 07:16 PM
So check ebay for a D2R replacement?? Has anyone replaced there healdights before??
Where can I get a clear strip for the city light?? Sorry for the newb questions...
Old Sep 8, 2009 | 07:17 PM
The high beams are on when the low beams are on...The top lamp looks yellowish and the low lamp looks bluish.. I wanted them to match...
Old Sep 8, 2009 | 10:10 PM
LightsOut's Avatar
SIETESG
vendors here sell replacement bulbs. look in the market place.
Old Sep 8, 2009 | 10:32 PM
code2424's Avatar
You mean fog light? You can turn it off and just have low beams.
Old Sep 14, 2009 | 10:50 AM
Oh, how do you turn the fog light off? I didn't know that...
Old Sep 14, 2009 | 11:58 AM
surma884's Avatar
On the light switch you will see on the inner side (closer to the steering wheel) there is a **** you can turn to the off position. The outer part is for the main lights.
DRG35R
Jan 31, 2016 07:14 AM
Rinaldi
Dec 2, 2015 05:29 PM
aaron3719
Sep 29, 2015 10:12 AM
wow600rr
Sep 28, 2015 11:50 AM
Detailed Image
Sep 28, 2015 07:04 AM
