Do I Need A New Transmission?
Sep 15, 2009 | 07:23 PM
Hi,
I bought my 03 6mt coupe about 3 years ago with absolutely no problem at 60k. I just hit 103k and I feel like its harder to put it into 2nd gear. sometimes it feels like its grinding to get in gear and its starting to grind putting it into 5th.
has anyone ever experienced this problem before? will i need a new transimission and how much does that ususally cost in cdn $?
Thanks for any input!
Reply 0
Sep 15, 2009 | 09:56 PM
When was the last time the transmission fluid was changed? I would start there first before buying a new transmission. Use good quality synthetic fluid. I had a grind on my 6spd going into 2nd gear; done 80000kms on the original fluid. Switched to Redline MT90, the shifts are now silky smooth.
Reply 0
Sep 15, 2009 | 10:27 PM
thanks for the tip. ill look into first, however i thought you never changed transmission fluid? is that wrong or is that only when u experience gear issues?
also, is this not a sign the transmission is beginning to show problems as well?
any input is appreciated.
Reply 0
Sep 15, 2009 | 10:35 PM
more info on this would be nice, got i got the same problem that mentos has..
Reply 0
Sep 15, 2009 | 11:04 PM
Quote: thanks for the tip. ill look into first, however i thought you never changed transmission fluid? is that wrong or is that only when u experience gear issues?
You've never changed your transmission fluid after 100K miles? You'd better get on that ASAP!! Go to a Nissan dealer and buy the necessary quantity of their manual transmission fluid and swap it out.
I like to change mine every 30K miles at the very most. It's cheap insurance for one of the most expensive components of your car and is real easy to do.
You should also try to change your fluid in the clutch as well and also the brakes if they've never been done.
Reply 0
Sep 15, 2009 | 11:20 PM
Quote: You've never changed your transmission fluid after 100K miles? You'd better get on that ASAP!! Go to a Nissan dealer and buy the necessary quantity of their manual transmission fluid and swap it out.
I STRONGLY AGREE...don't skimp when it comes to ANY fluids in your G
here's a qoute from cars.com
"Manual: In a manual transmission, the problem is not so much the fluid degradation, but rather fluid contamination. This contamination occurs over time as the synchronizers, bearings and gears in the transmission wear out. The resulting metal particles then float around in the lubricant. And we all know that oil with microscopic particles of metal in it does not lubricate as well as clean oil. So if these contaminants are not drained out, they will shorten the life of your transmission."
Reply 0
Sep 15, 2009 | 11:37 PM
I'm pretty sure he's talking in Kilometers, not miles.
Reply 0
Sep 15, 2009 | 11:47 PM
I also forgot to mention that you definitely will want to change out the fluid in your differential. I recommend Amsoil full synthetic as a replacement for that. If the tranny fluid has never been changed, then you can bet your a$$ that the diff. fluid hasn't been either.
Reply 0
Sep 16, 2009 | 12:57 AM
I have an 04 coupe and the 5th gear grinds sometimes. I am going to change the manual transmission fluid. For the clutch fluid is the syringe best to do it with?
Reply 0
Sep 16, 2009 | 01:18 AM
thanks for all the great input.
im the farthest thing from a mechanic but i can do a oil change
is it just as simple? should i just bring it to any mechanic? if there are any video tutorials lurking around a link would be great. im gonna check youtube for any vids...
thx and i really hope that smooths out my tranny issues.
Reply 0
Sep 16, 2009 | 01:22 AM
Quote: I have an 04 coupe and the 5th gear grinds sometimes. I am going to change the manual transmission fluid. For the clutch fluid is the syringe best to do it with?
Start with the syringe to siphon out all the old fluid from the reservoir. Then wipe the sludge from the bottom of the container. Refill with clean fluid and flush the remaining fluid in the system.
Reply 0
Sep 16, 2009 | 02:25 AM
ok thanks will go look for a syringe in walmart tomorrow.
Reply 0
Sep 16, 2009 | 12:30 PM
Same problem here.. grinding into 3rd gear at RPMs above 4K
Reply 0
Sep 16, 2009 | 12:47 PM
Similar problem.
Does anyone have tutorials for these changes (manual transmission, clutch, dif)?
Reply 0
Sep 16, 2009 | 12:51 PM
Quote: Start with the syringe to siphon out all the old fluid from the reservoir. Then wipe the sludge from the bottom of the container. Refill with clean fluid and flush the remaining fluid in the system.
I just got off the phone with infinity and these are the prices they quoted me:
to change:
differential oil - $79.95
Transmission oil - $109.95
bleed brakes - $84.95
the infiniti rep said there is no option to change clutch fluid. is there another term they use so i can get a price?
thx!
Reply 0
