ECU Part Number
Old Sep 18, 2009 | 05:32 PM
Tukeeg35's Avatar
ECU Part Number
Hi all,
Im thinking of getting an UpRev Osiris tune and i need to know my ECU part number, but i have no idea how to find it
Could someone point me in the right direction/tell me how i can find it?
Thanks,
-Tukeeg35
Old Sep 19, 2009 | 12:23 PM
LMG_35C's Avatar
Best way is finding someone with the UpRev Cipher to read the ECU part number, or call dealer parts department and give them your VIN.
Old Sep 19, 2009 | 01:34 PM
V35 Skyline GT's Avatar
6MT Coupe
Have mine but it's for a 2006 revup VQ, so not the same ECU pt# for a 2004 non revup.
Dealer call with VIN as suggested above best way. UpRev says to do that way if you have no other resource.
Old Sep 21, 2009 | 11:59 PM
BradBlick's Avatar
n00b question but I have an 06 6sp g, what would messing with the ECU even accomplish without a turbo?
Old Sep 22, 2009 | 01:12 AM
6MT Coupe
Better AFR's for starters. My 2006 factory AFR's suck big time (lean).
Old Sep 24, 2009 | 11:44 PM
Latech08's Avatar
what ECU would i need for a 2006 G35 AT ?? revup or no since my car is an AT? si
Old Sep 25, 2009 | 11:22 AM
6MT Coupe
Correct, is not a revup VQ.
Old Oct 12, 2009 | 11:07 AM
OffWithHisHead3's Avatar
So i called the dealership to get my ECU part # and they said they can't give it too me??
Old Oct 12, 2009 | 01:14 PM
LMG_35C's Avatar
That BS. Call another dealer or ask for parts manager.
Old Aug 5, 2015 | 11:23 PM
richy.'s Avatar
Talking need to replaced the ecu on my 03 g35 6mt will need to be exact the same matching
hello I have 03 g35 6mt the has bad ecu or ecm I get one from a local pick and pull but the number wont match also I fund one on ebay the add said is for 03 g35 6mt but still the numbers wont match exactly no need to know if I number will matter or not my is
DC MEC31-902 A1 3418
or if some one has one ill buy it so any help will be appreciate thanks.
Old Jan 3, 2016 | 02:18 PM
warchild3030's Avatar
or if some one has one ill buy it sio any help will be appreciate thanks.
I have this same issue. Im trying to buy a replacement ecm and dont know EXACTLY what i need to match. Were u able to complete this swap successful? Or anyone?
Old Aug 9, 2023 | 01:11 PM
JoshHan's Avatar
Early production 2003 manual sedan model
Were you able to find out what you needed to do.
I realize this is a thread is almost 10 years old, but what was the case with the part number situations, I understand the outside numbers will not match. How do I tackle this if I don’t know anyone who has the means to read the ecu part number with the computer? Thank you for any help!
Old Aug 11, 2023 | 10:41 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The part number is the sticker on the outside of the housing, yes it will match. There were like 20 different ECMs for these cars though so make sure your MEC number matches.
Old Aug 11, 2023 | 10:56 AM
seymore4's Avatar
m56
It doesn't need to match EXACTLY, as long as its from the same trim level (engine, trans, cruise control etc) we can just flash it with Uprev and make it work. You'll have to either get reprogrammed at the dealership or have NATS bypassed with Uprev anyways...
Let me know if you need help
Old Aug 11, 2023 | 11:02 AM
cleric670's Avatar
BANNED!!!
That's a great point, plus you wouldn't have to worry about towing the vehicle to the local Nissan dealership to get the ECM programmed. It would probably only be a little more $$ just to get an Uprev tune.
