3m headlight restoration kit
Old Oct 25, 2009 | 02:40 AM
  #31
klee's Avatar
great tips viper. thanks buddy
  #32
Marlin's Avatar
Originally Posted by vipers
It's only $20 in pep boys why did you order it?
Eh was buying a bunch of things at Amazon.. plus it was like $12 after rebates on Amazon.
Old Oct 26, 2009 | 12:16 AM
  #33
kgilmore11's Avatar
If I were to do this and find out its inside, Is there a way of cleaning the inside??
Old Oct 26, 2009 | 12:36 AM
  #34
Gdup35sedan's Avatar
ENVautoDetailing.com
i used blue magic metal polish and it took the hazing right off, good as new.
-GP-
Old Oct 26, 2009 | 08:02 AM
  #35
vipers's Avatar
No...the only way to do that is by breaking the seal and opening up the headlight. There's a DIY somewhere on it I'm sure of that.
But like I said, I would do the headlight kit either way. When I get my next car I'm going to use it (unless it's new) cause the lights really look that much better.
Old Nov 7, 2009 | 03:08 PM
  #36
WILLIE BEANS's Avatar
for whatever reason its not allowing me to embed the video so heres the link to it ..
3M™ Headlight Lens Restoration System
Old Nov 7, 2009 | 03:48 PM
  #37
blackhat5's Avatar
I used the 3M kit and it definitely removed some SERIOUS defects in the headlight. My only issue now is the glass isn't as clear as a new headlight, and there are fine swirl scratches all over the entire light. Maybe I didn't keep it wet enough while I was wet sanding, but if anyone knows how to clear it up more let me know. I tried Meguiars PlastX but that junk didn't work at all.
Old Nov 7, 2009 | 08:00 PM
  #38
Drowe303's Avatar
I just went to autozone to buy the 3m restoration kit but they didnt have it. Instead, I purchased the Meguiars Plastx. $9.99. My headlights were not terrible but showed some signs of cloudiness. I would recommend it to someone whos headlights are not HORRIBLE but need work. Heres a before and after pic. Sorry for the quality, it was taken with my cell phone. Also there are different background reflections so its kind of hard to compare perfectly.
Before
After
Old Nov 17, 2009 | 09:54 PM
  #39
scottfedm's Avatar
to get rid of the swirl marks just spend more time with the gray foam rubber sanding disc (II forget the name) and use a lot of polish. Now on another note...i decided to get a bit stupid/ambitious. I know this worked on headlights but how about surface scratches on paint...GUESS WHAT?!?!?! It works there too. But only use the gray foam rubber disk and and the foam polishing disk. And do go at for too long or you will go thru the clearcoat. But if you are careful....it takes scratches out you can't normally get out with regular compound.
Old Nov 17, 2009 | 10:55 PM
  #40
gsoto999's Avatar
I used Meguiars PlastX, I bought it for $8 at Kragen auto and made my headlights look like new!!
Old Nov 20, 2009 | 10:09 PM
  #41
Bruin003's Avatar
Sound like I can just use my random orbital buffer w/ headlight polish and all the haze should come out....
Old Nov 24, 2009 | 04:15 PM
  #42
tegraphile's Avatar
Gonna have to try this when I get a chance. I use PlastX, but I think the imperfections are deeper than that. A wet sanding kit would do the trick.
Old Nov 24, 2009 | 06:08 PM
  #43
bocatrip's Avatar
I've been keeping an eye on mine for the last 6 years and I live in the hot temperatures of Florida. I have kept a coat of polish on them whenever I see even the slightlest bit of fogging. They look as new as the day I picked the car up. I guess the secret is to get to the discoloration asap or the PlastX also does a good job.
Jusseth
Sep 13, 2020 12:25 PM
zoop425
Mar 29, 2016 05:51 PM
JG_G35
Accessories
Feb 25, 2016 01:44 AM
youngdip631
Lighting
Aug 27, 2015 03:49 PM
RA081024
Aug 18, 2015 07:03 AM
