A/T Shift Mode
Old Nov 1, 2009 | 12:03 PM
jaysizzlecity2's Avatar
A/T Shift Mode
Is there anyway to change the gear ratio? Cobb or bullydog? I hit 3rd gear and It shifts for you about 1 second later. It makes you think your in 3rd but it really not. By changing gear ratio I think I can get better fuel economy.
Old Nov 1, 2009 | 01:01 PM
thescreensavers's Avatar
Mr.202?
There is no way to change gear ratios, we do not have a CVT.. Maybe if you want to change FD gear, and rebuild the tranny?
any how you can try a grounding kit which is suppose to make your shifts faster/more crisp.
But if shifting into 3rd is taking too much time something might be up. It should be as fast as 1>2
Old Nov 1, 2009 | 02:42 PM
Iamnotkento's Avatar
get a MT.
Old Nov 1, 2009 | 02:58 PM
Well after researching the 6mt I didn't want it.
Old Nov 1, 2009 | 03:07 PM
I see the gear in 3rd then one second later I feel the tranny shift and rmp drops. I'm looking for better quick shifts and I'll look into a grounding kit. This only happens when driving slow to get better mpg.
Old Nov 1, 2009 | 03:10 PM
Neu Era's Avatar
After I installed my grounding kit, I noticed a difference in the speed of shifting. Mine doesn't shift unless I make it.
Old Nov 1, 2009 | 10:24 PM
jebus2006G35's Avatar
what grounding kit did u put?
Old Nov 1, 2009 | 10:47 PM
gary c's Avatar
The grounding kit is a good idea, I've been using the Gordee Gounding Kit for a few years and noticed a difference when I first installed it. SXEXCX (Sean) makes a kit that's good too, he's here in SoCal. You also might try a drain/refill on your AT with Red Line synthetic fluids, AT's love that stuff!
Gary
Old Nov 1, 2009 | 10:51 PM
Mr.202?
^^ if you are still under warranty only use Nissan Matic-J fluid
just wanted to put that out there :O
Old Nov 2, 2009 | 12:50 AM
musti82's Avatar
try sprintbooster! i did and still have it on. best and easiest mod to do if u at least wanna increase the response timing.search on the forum, there r many threads.
Old Nov 2, 2009 | 05:28 AM
Neu Era's Avatar
I had one made from a guy on g35club.
Old Nov 2, 2009 | 09:30 AM
No more Matic-J fluid its nissan s now..........
Picture Share
Feb 4, 2018 12:41 PM
RWDguy4238
Sep 30, 2015 12:13 AM
master111
Sep 25, 2015 08:32 PM
blnewt
Sep 25, 2015 01:48 PM
