Two G35's and they BOTH stumble/hesitate periodically.
Old May 7, 2010 | 11:09 PM
  #31
rrb_G's Avatar
I have an 07 g35x with the 5at, and I notice these issues as well. I've noticed that the smoother I apply the throttle, the less I notice it....but I can't keep it from happening at all. GT-ER, did you ever discover what the issue was with your car, or are you still experiencing the same things?
Old May 8, 2010 | 12:26 AM
  #32
GT-ER's Avatar
it still does it every once in a while...I just ignore it.
Old May 8, 2010 | 10:46 AM
  #33
rrb_G's Avatar
Me too, but sometimes it bothers me more than others. I guess if I was 100 percent sure that it wasn't a slipping transmission, or failing TB or whatever else it could be with the drive by wire system......anyways I feel like what everyone here calls normal is really an infiniti problem. Just wish they would admit it and address it.
Old May 23, 2010 | 08:37 AM
  #34
stevec1129's Avatar
I was talking to my buddy who is a mechanic about my shuddering and "hiccup" in rpm's at 3,750rpm when in 2nd 3rd and 4th if applying light throttle unttil until I hit that rpm mark whihch is where I experience this hiccup in tiptronic. In d mode I experience this in 2nd around 25 mph its a slight jerk/bump I experience when applying smooth linear throttle. I had the shutter at 40 even after applying tsb for throttle sensitivity. My buddy asked if the Tps - throttle position sensor was checked..I think it could still be the torque converter but hope this helps. Google tps shudder/hesitation and sure enough its brings up a lot
Old May 23, 2010 | 12:21 PM
  #35
herrschaft's Avatar
^After googling that, apparently every other car out there has this problem as well and its because of the TPS. The torque converter hiccup happens at around 3K RPM.
Old May 23, 2010 | 02:51 PM
  #36
jibberjabbers's Avatar
I think I have this problem with my 6mt. Feels like the car is about to break down, but all of a sudden, after a certain rpm, all is normal.
Old May 23, 2010 | 10:22 PM
  #37
GT-ER's Avatar
I haven't had it happen in a while, or maybe I just don't notice it anymore.
Old Jul 15, 2010 | 02:50 PM
  #38
dias724's Avatar
jerking motion
My 06 coupe is doing this and its very anoying!! i had an 04 and i never felt this im crusing on the freeway and all of a sudden It happens jerking motion!!!
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
teamghost
Jul 28, 2015 04:52 PM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
