Stiffer spring in front how is performance?
Old Nov 4, 2009 | 03:55 PM
tightvpkid's Avatar
I currently have the tein cs coilovers and the front keeps on bottoming out when i hit a small pot hole. I bought front springs from a member on here that is suppose to fit into the tein cs. Tein cs rating is 392 lb and the new front spring rating is 502lb. Since i am only switching out the two fronts, how will this effect the performance of the car. I have the electronic damping as well which i can adjust a little but i can't find how much it will adjust it to(range). Most coil overs i see they are either equal front and rears or the rear is stiffer. But in this case my fronts are going to be stiffer so they wont bottom out...Any opinion or any ideas on how this will change my performance?
Old Nov 4, 2009 | 03:59 PM
Kris79's Avatar
battle froggy
car would prolly understeer more. i would be more concerned about wearing out those shocks. cs shocks arnt that great.
Old Nov 4, 2009 | 04:04 PM
tightvpkid's Avatar
hm...so should i switch them out or just leave the original cs spring in there? I got them fairly cheap from another member on this forum...
Old Nov 4, 2009 | 04:09 PM
Kris79's Avatar
battle froggy
i wouldnt. the point of going cs is cause you want a soft comfy ride. you might be better off sellign these and goign with another coilover.
Old Nov 4, 2009 | 04:11 PM
Kris79's Avatar
battle froggy
ey ur local give me a call 415-594-0030 i will explain more.
Old Nov 4, 2009 | 04:19 PM
kennymo's Avatar
let me know if you want to sell your coilovers. im in the bay area also
Old Nov 4, 2009 | 04:24 PM
tightvpkid's Avatar
awesome thanks kris give you a call later when im out of work..
Old Nov 5, 2009 | 04:20 PM
tightvpkid's Avatar
TEIN'S Repsonse:
All TEIN coilovers can accept a range of spring rates, recommended at no
more than plus or minus 2kg from factory spec without having the dampers
re-valved. Outside of this range, re-valving is recommended for proper
performance.
As such, the 9kg springs would be able to be utilized the provide more
aggressive suspension performance without modification to the dampers.
The noted part number utilizes 25mm shorter springs than that which was
included with your kit, which would be beneficial in offsetting the increase
in spring rate to maintain a similar height adjustment range.
Even though kinda of still debating...since tein cs are not that great i heard...
jsimonk
Dec 22, 2023 03:49 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
Tukeeg35
18 Inch
Aug 25, 2015 06:45 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
