Rattling/Grinding Noise
Old Nov 8, 2009 | 01:08 PM
willis555's Avatar
For the past couple of months, I have been hearing this rattling/grinding noise whenever I accelerate in pretty much any gear (I have a 2004 5AT G35 Coupe, but I always use manumatic mode). This noise is really starting to bother me, and I have no idea what it is. When the windows are down, it sounds like it is coming from under the car. When the windows are up, I hear this metal-on-metal type noise coming from the passenger side of the car whenever I accelerate. It is a completely different sound when the windows are up, and it comes from a completely different location then it does when the windows are down. Any ideas what it could be?
Also, I have no lights on the dashboard at all, so I am kind of confused as to where this noise is coming from.
Thanks!
Old Nov 8, 2009 | 08:10 PM
TofuProductions's Avatar
exhaust gaskets/loose bolts.
thats the case for me at least, I just noticed it yesterday and am getting new gaskets tomorrow and will put them on Tuesday.
Check yours.
Old Nov 9, 2009 | 07:42 PM
unwise's Avatar
Post a youtube clip of the noise... does it get louder as you gain speed? How about on turns?
Old Nov 10, 2009 | 01:56 AM
g unitz's Avatar
Thanks!
for your dash lights, check if your dim switch works, if not u have a blown fuse. there r a set of fuses behind your battery, ur manual does not tell u that
Old Nov 10, 2009 | 05:53 PM
willis555's Avatar
What I meant by no lights on my dashboard was that no lights such as engine check or AT check were on. My dashboard lights work fine haha. I just meant that there were no lights on that would tell me where the problem was. Thanks though.
Old Nov 10, 2009 | 06:33 PM
mustangpunx's Avatar
Do you have less than 60,000 miles on the car? if so take it to the dealer! It could be the oil consumption problem. check your oil levels.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
