HELP, how do I disconnect headlight harness???
Old Nov 10, 2009 | 03:39 AM
Mr_pharmD's Avatar
I cant seem to figure how to take this thing off. I cant get the headlight harness to come off and it's killing my fingers. Is there an ez way to get this off????
Old Nov 10, 2009 | 04:08 AM
01msmis's Avatar
I usually use a flat head screw driver. Give it a try
Old Nov 10, 2009 | 06:20 AM
Mr_pharmD's Avatar
thanks.. thats what i did but my fingers hurt like a mother trying to get them off by hand.
Old Nov 10, 2009 | 10:21 AM
G35Aaron's Avatar
If you feel around you will feel a little space on one side that feels like a gap on the connection. You need to use a flat head screw driver and press down on this part because it is a clip that holds it in place on the connection. It is like every other clip connection on the car that has a certain place that is needs to be depressed in order to be released. I know it is is hard to get to because I just replaced my lights about a week ago. It is possible it just takes a little bit of time and effort to get it off.
Old Nov 10, 2009 | 12:14 PM
ntrinsik's Avatar
Try using a flatheaded screwdriver from the wheel well. I found that easiest when I was swapping my headlights.
Old Nov 10, 2009 | 12:24 PM
G35Aaron's Avatar
Yeah forgot to say that. It is a lot easier to get to the spot when you lift the front end and open the wheel wells.
Old Nov 10, 2009 | 01:19 PM
GreenGoblin's Avatar
The goblin resurrection
I use my vise grip fingers... if that fails a pick tool is the best bet,
Danielek
May 1, 2022 01:28 PM
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
