New drive belts make horrible squealing sound
Old Nov 16, 2009 | 01:53 AM
paymon's Avatar
I decided it was time to replace my stock worn belts at 90k miles. I replaced them with a pair of Duralasts from Autozone. Ever since they have been squealing horribly, most of the time when the car is first started. It used to go on for a minute or so.. but now its down to about 15-25 seconds. I checked the belts and they are on there good.. less than quarter inch of play either way. Should I put some belt dressing on them? Will the sound gradually go away? Or should I fork over extra $$ for gatorbacks or OEM ones and have them installed in hopes of getting rid of this sound?
Old Nov 16, 2009 | 01:54 AM
Rodrigo's Avatar
OEM belts is your best bet
Old Nov 16, 2009 | 02:01 AM
Benny's Avatar
Tighten them up some more. Happen to me also, after tighten no more squeal.
Old Nov 16, 2009 | 02:05 AM
umair's Avatar
are the belts getting wet?
Old Nov 16, 2009 | 10:59 AM
paymon's Avatar
no they are not getting wet either... it rained but that was over 3 weeks ago! still making that horrible sound...
Old Nov 16, 2009 | 11:03 AM
2K6G35c's Avatar
It's not the belts, it's what the belts slip into. It' the pulley, you need to get that replaced asap. That's what hapenned on my Max several months back. My mechanic swapped out the belts and that didn't fix the problem. He then swapped out the pulley and, woops problem solved. Replace it and then tell us how it runs, should run like new again.
Old Nov 16, 2009 | 11:08 AM
paymon's Avatar
what are the pulleys called? i need 2 of them right? where can i get them?
Old Nov 16, 2009 | 11:44 AM
CLEANBS's Avatar
its because you didnt use OEM belts
Old Nov 16, 2009 | 11:18 PM
2K6G35c's Avatar
I'm sure the guys at O'reilly's will know what you need.
Old Nov 17, 2009 | 07:41 AM
Mike Mike17's Avatar
Just tighten them in happened to me after i had me belts changed. After your car sits for a few hours and you turn it on it makes a terrible squeling noise right? i just got mine tightened it it stopped
Old Nov 17, 2009 | 09:10 PM
scottfedm's Avatar
did you say you have been squealing for 3 weeks now? They are probably crystallized by now. Buy new belts...oem or other, it doesn't really matter much here except for longevity of the belt. Make sure they are sitting on the groove and make sure they are tight! Word of advice. When you think they are tight enough....tork em a little more. The specs say 20ft lbs I believe. Go a bit more.
Old Nov 17, 2009 | 10:57 PM
paymon's Avatar
The belts are only 3 weeks old. How can I tighten them? How many bolts are there and where are they located?
Old Nov 17, 2009 | 11:09 PM
04G35NYC's Avatar
here, read my thread i made before.
https://g35driver.com/forums/engine-...t-changes.html
Old Nov 18, 2009 | 08:08 AM
if you cant do it go to a local gaststaion or like a jiffy lube and have them tighten them it should take them like 5 min and youll be in and out
Old Nov 18, 2009 | 10:51 AM
JuniorBass's Avatar
Did you replace the belts yourself or go to a dealer? With you asking how to tighten, i assume you did not do the job yourself.
