Automatic lock PROBLEM!!! PLEASE HELP!!!
Old Nov 19, 2009 | 02:50 AM
xzAZNlonerzx's Avatar
hi i just bought a g35 and the lock is not doing what it should only when i get super lucky it would lock. Like when i press the lock on my key or when i press it inside the car it doesnt seem to work on both side. when i press it would make a very tiny clicking sound. please could someone help me to solve this problem or find a solution. please help me
Old Nov 19, 2009 | 05:02 AM
klee's Avatar
if your car is still under warranty then bring it to an infiniti dealer..
Old Nov 19, 2009 | 05:50 AM
it an 03 so i dont think so it not under any warrenty. i just bought the car off an private seller. is there any other way i could fix it or could it be a fuse???
Old Nov 19, 2009 | 08:01 PM
gsoto999's Avatar
check your battery out, same thing was happening to me my car wouldnt lock from the key alarm but it would from inside.. a couple weeks later, my battery died.. check it just to make sure because it might be a sign of a weak battery.
Old Nov 20, 2009 | 05:48 AM
oh my car it wont let me lock from the inside of the car either so i dont think it the battery, but i will check it out to make sure. thank for the advise. yea it so sad that i have to manually lock my door when i get out it pretty sad lol.
Old Nov 20, 2009 | 10:13 AM
mferek's Avatar
Sounds like the locking mechanisim needs to be replaced. It should be the fuse (if there is one, i don't know) becuase if that was blown, it wouldn't ever work. Is it only one side that doesn't lock or are both sides affected?
Old Nov 20, 2009 | 11:39 AM
cpufreak3's Avatar
Sounds like the door lock actuator.
Old Nov 20, 2009 | 10:04 PM
Bruin003's Avatar
they sell infiniti door lock actuators on ebay...might be work a quick look.
Old Nov 20, 2009 | 11:18 PM
it happening to both side so they would just go out together like that. well i will look into the actuators. so is it hard to change it does anyone know.
Old Nov 21, 2009 | 12:24 AM
Marlin's Avatar
Probably the actuators are out.. My drivers side does the same thing when it is hot (and if I lock unlock and lock again quickly it will get stuck after the 3rd action) and forces me to roll down the window through the keyfob to open the car door.
Old Nov 21, 2009 | 04:38 AM
wow does it really get that back that you cant even open your door. i mean mine doesnt do that. i think it just that electric actuator that going out but it kind of weird that it would go out on both side at the same time. so yea i would love to have more in put on this if anyone have anything else to say that would be great too.
Old Nov 21, 2009 | 11:01 AM
cpufreak3's Avatar
You can still unlock using the keyhole, right? That's what I do...
Old Nov 21, 2009 | 11:22 PM
yea it can still be unlock with the keyhole, but it getting really annoyying so i think i need to fix it asap because i look stupid locking my door by hand lol.
Old Nov 21, 2009 | 11:34 PM
cpufreak3's Avatar
Your options are to buy an OEM one from ebay or somewhere else for $200 and swap it.
Or a makeshift one for $5 with a more complex install: https://g35driver.com/forums/interio...uator-fix.html
Old Nov 22, 2009 | 06:23 AM
thank alot man i think i'm going to do the 5 buck actuator thing seem pretty good i like it. anyway thank alot for all the help i love this forum great people and great help.
