Just got rejected from the dealer for a new engine replacement..
Old Nov 29, 2009 | 08:10 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Originally Posted by RichardLe187
I switched to Mobil 1 Fully Synthetic and used a Mobil 1 premium oil filter. Maybe i should switch oil brands..? Thanks for all the replies!
FWIW,
I had more consumption with M1 than I did with Amsoil in my truck.
Old Nov 30, 2009 | 09:54 AM
TofuProductions's Avatar
I remember my car back then (and mine was a NON-revup) burned through 5 qts (entire block's worth) within 1000 miles.
My oil pressure light even came on.
Luckily I know everyone at Infiniti very well so I was approved a new motor about a month ago.
Good luck..
Old Nov 30, 2009 | 11:47 AM
str8dum1's Avatar
do another OC test but this time siphon the oil out from the dipstick tube.
otherwise dont worry about it.
Old Nov 30, 2009 | 12:45 PM
smokincoupe's Avatar
yeah drain some out... that will def get you approved for a new motor
Old Nov 30, 2009 | 12:48 PM
partyman66's Avatar
I thought I remember reading that the dealer seals and marks the dipstick to prevent this from happening.
Old Nov 30, 2009 | 01:00 PM
lilindienplaya's Avatar
Dont pull that **** on the dealers man, come on. your motors running fine, theres no need for a new motor.
Old Nov 30, 2009 | 02:32 PM
Andrei's Avatar
Went back to the dealer after undergoing the 1000 mile oil consumption test. Dealer said my 07 G35 coupe was burning approximately .25 of a quart every 1000 miles and that was considered normal. Is that really normal?? Sounds bad to me. What do you guys think I should do?
Don't feel bad. Mine went through 6 qts in 2600 miles all out of the blue because it wasn't burning any before. But I also think someone drained my oil but I
Old Nov 30, 2009 | 04:19 PM
mine was low by 21/2 qts two days after i took my car in for warranty repair they checked the air tire tread and all that but didnt catch my oild being at half level WTF
Old Dec 2, 2009 | 04:57 AM
RichardLe187's Avatar
The dealer didn't seal or mark my dipstick. I was able to check my oil level daily with the dipstick while undergoing the OC test. Hmm..
Old Dec 8, 2009 | 09:49 PM
TheG35Dude's Avatar
Oil consumption also has to do with how you drive it. It is not unreasonable to expect oil to get past the rings at higher engine rpm because it becomes so much harder for the rings to scrape oil off the cylinder walls than it is at low rpm. So if you drive it nice (keep revs below 3000) you won't burn much oil. If you drive it like you stole it expect oil consumption to increase.
Old Dec 8, 2009 | 11:41 PM
Texasscout's Avatar
I agree with that statement in some cars. Not mine. I change my oil just before each Raging Bull Texas Stampede and we run over to 500 miles (we will do over 780 this year!) and I see no accelerated oil consumption in my car.
Old Dec 9, 2009 | 08:07 PM
airdetail's Avatar
when i had my sti I remember people saying something about mobil1 synthetic being bad because at high temps, it would break down very easy and what ever problems go along with that..lol sorry im no tech but it could have to do with the mobil1..check into it
Old Dec 12, 2009 | 05:16 PM
I only push it past 5k rpm occasionally, not that often. If this is true, its ironic how Infiniti boast the "Rev-Up" engine when u cant even push it to the limits..
Jiggerjuice
Oct 5, 2015 02:33 PM
Ednica87
Sep 5, 2015 02:59 AM
Jiggerjuice
Aug 17, 2015 08:41 AM
ghost_g35
Aug 7, 2015 10:31 AM
joedaddy1
Jul 28, 2015 02:58 PM
