car turns off while driving!!!! help please!!
Old Dec 2, 2009 | 11:32 PM
jibberjabbers's Avatar
What is the car idling at? If it idles below a certain rev, the car will shut off.
It's not the battery. You can unplug the battery and the car will still be running. If our car is running on the battery, then we have one crappy car.
Old Dec 3, 2009 | 10:24 AM
OPTiK's Avatar
Originally Posted by partyman66
Hit the brake... it'll probably shut off unless the engine is revving like crazy to create more current since it thinks the battery needs charging.
He drove it to a car shop after (so he was braking, idling,etc), and they turned it off by disconnecting the alternator i think.
Old Dec 3, 2009 | 10:55 AM
wannascooby's Avatar
Originally Posted by OBG3506
Check for loose battery cables and Hope its not an electrical problem
NVM I read other posters comments
Old Sep 11, 2013 | 09:53 PM
rdavis's Avatar
i have a similar problem. its about 76 degrees outsides and its happen to me mulitple times already..car shuts off and throws the check engine light... leave it alone for about 20 minutes car starts up perfect like nothing happen..car has full tank of gas... i have a cai in my car
Old Sep 12, 2013 | 06:12 AM
Blue Dream's Avatar
I drove ttrank's car solo
If the SES pops up have the code read and report back here. Until then we can just guess what the issue is and that's probably not helpful to you.
Old Sep 12, 2013 | 12:49 PM
twentyeggs's Avatar
Throttle position sensors are about 150-200 bucks. I don't know how much either for the G but it will be closer to the 150. with some basic electrical skills you can replace it yourself. Maybe even plug and play, I will take a look later today. It is part of the throttle body. There is also a accelerator position sensor so make sure you get the right part, this one goes to your throttle petal.
a faulty position sensor will definitely cut your engine mid drive.
Old Feb 11, 2016 | 12:04 PM
Ricardo_Galeno's Avatar
Did you ever find out what it actually was? I had the same problem on my 05 coupe 5at last night.
Old Dec 15, 2017 | 10:30 AM
skntss's Avatar
Skyline 350GT
Smile
Originally Posted by sergg35
wasup fellas, i have a 04 auto coupe. driving the g to skool today and going there and back it died on me 4 times!!!!! not once 4!!! ... wut happens is the car jus dies and all my lights come on ( vdc, check engine, slip, ect)... has anyone had this problem???
I had the same problem with my Nissan Skyline 350gt 04 manual coupe. change the Camshaft Position Sensor Circuit Bank 1 if you having code P0340, the sensor is the passenger side for Infiniti G35 and for Nissan Skyline 350gt it is the driver side. after replacing the cam position sensor clear your engine light by resetting the ecu.
Procedures to reset Infiniti G35/ Nissan Skyline 350gt.
To locate your Infiniti G35/ Nissan Skyline 350gt battery, open your hood and find the battery tray on the (passenger side for Infiniti G35) / (driver side for Nissan Skyline 350gt) of the upper engine bay. If you wish to learn how to reset your G35/Skyline 350gt ECU by way of the pedals, continue on.
  1. Get into your vehicle and turn the ignition switch to the “ON” position, you do not need the ignition key inside your fob for this step.
  2. Push down on your gas pedal firmly and then fully release it. Repeat this process 5 times, making sure to distinctly release and depress each time.
  3. Now wait for 7 seconds and then push down on your gas pedal and hold down on it until your Check Engine Light starts to blink.
  4. Once your MIL begins to blink, release the gas.
  5. Wait about 10 seconds and then push down on your gas pedal and hold for another 10 seconds
  6. Release your gas pedal
Then you good to go!
Problem fixed for me
Hope this helps
Old Dec 15, 2017 | 10:32 AM
skntss's Avatar
Skyline 350GT
Smile
  7. You should now be able to turn the key to the “OFF” position and your MIL status should now be cleared.
Hope this helps
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
ddietz97
Jul 26, 2015 06:16 PM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
