superchaged g vs. kenne bell lightning
Old Dec 3, 2009 | 09:18 PM
smokincoupe's Avatar
supercharged g vs. kenne bell lightning
will a vortec supercharged g35 coupe making around 410 hp beat a 03 ford lightning with a kenne bell making around 480 hp???? from a dead stop and a roll what do yall guys think will happen???
Old Dec 3, 2009 | 09:53 PM
come on guys anybody know what would happen??
Old Dec 3, 2009 | 10:12 PM
LightsOut's Avatar
SIETESG
nope it wont. that tq on that lightning will just blast you off the line. it will take after the 1/4 mile for you to catch up and pass it. Gearing on the lighting will fail after the 1/4 mile
from a roll you'll take him, depending when boost kicks in for either car will make the difference in the race. since our G's perform best at top end, thats where you will shine.
Old Dec 3, 2009 | 11:19 PM
GT-ER's Avatar
I kinda agree with Lightsout. The lightning ( assuming he has good tires ) will launch like a ****...you probably will loose from a stand still. From a roll though you'd probably win.
Old Dec 3, 2009 | 11:27 PM
partyman66's Avatar
Depends on what the Lightning has for rear tires. If it's making that much WHP, it's going to be really likely to light up the tires... especially if they're the stock size. I would imagine your G has larger than stock tires... right?
I think a good G driver would win off the line, and then the lightning would pull on you and probably pass you with ease due to the gargantuan torque... and stay in front up till around 110 MPH at which point the G would start to come back due to aerodynamics and gearing. So basically, the Lightning should win.
Old Dec 4, 2009 | 09:35 AM
Iamnotkento's Avatar
No way a g will beat a lightning off the line. G is slow off the hole. In the other hand lightning's massive tq will blow bast the G.
Can't mess with lightnings. Just listen to the other comments and race him from a roll.
Old Dec 4, 2009 | 01:47 PM
XLR8_'s Avatar
HERE IS A VID OF THIS RACE.... BUT I THINK THE G35 DRIVER IS LYING BECAUSE HE SAID LIGHTNING WAS CHIPPED OR HE WAS JUST A REALLY GOOD DRIVER
Old Dec 4, 2009 | 03:40 PM
ha yeah i saw that one before
Old Dec 4, 2009 | 07:37 PM
lajkhritw's Avatar
I accept with information:that tq on that lightning will just blast you off the line. it will take after the 1/4 mile for you to catch up and pass it. Gearing on the lighting will fail after the 1/4 mile.
______________________
Courtier conseil financement immobilier achat | Demande credit simulation plan de financement immobilier | Calcul pret projet financement immobilier travaux
Old Dec 4, 2009 | 09:22 PM
GT-ER's Avatar
The gearing on the lightning isn't the biggest issue...it's the aerodynamics. It's frontal area is twice that of the G.
Old Dec 4, 2009 | 10:53 PM
LightsOut's Avatar
SIETESG
aerodynamics is not going to change the outcome of the race. the gearing on the lighting is just going to fall flat even with a chip or flash. lightning only has 4 short gears
Old Dec 4, 2009 | 11:16 PM
GT-ER's Avatar
No...it has 4 LONG gears.
1st = 44mph
2nd = 77mph
3rd = 118mph
4th = 166mph
Our G's have FAR shorter gearing than this...although it has more gears. This was calculated using 2004 specs. While I agree it may not change the outcome of a 1/4 mile race...it will most definitely show from a roll when going over 100mph.
Old Dec 4, 2009 | 11:18 PM
LightsOut's Avatar
SIETESG
might have to double check what you posted. from what I remember the lighting topped out at 130, due to govenor. the cobra had a higher top end
Old Dec 4, 2009 | 11:20 PM
LightsOut's Avatar
SIETESG
http://www.fordlightning.com/statistics.htm
Old Dec 4, 2009 | 11:40 PM
GT-ER's Avatar
They posted even more mph per gear than I did ( they put 3.55 FD while my calculations were done using a 3.73FD )...and while it IS governed, any chip will remove that and it has nothing to do with the gear ratios.
