Eibach Pro-kit 04 G coupe Question
Old Dec 16, 2009 | 12:45 PM
Yen817's Avatar
Exclamation Eibach Pro-kit 04 G coupe Question
I have searched and searched about camber kits if they are necessary or not and the results I found are conflicting. Someone bought me a set of Eibach Pro-kit as a Christmas present for my 04 G coupe. I read that the rears are a must but what about the fronts? I have read that the fronts are not significant enough for a kit, is this true? I definitely want to this project correctly, but if I don't need a front camber kit then it would be great to save 300+ dollars. Just some advice from people who has the same setup would be great!
Thanks
Freaking excited about the drop!
Old Dec 16, 2009 | 01:02 PM
LightsOut's Avatar
SIETESG
are the springs Z or G springs? different drop and spring rates.
if they are G springs drop will be 1.0 all around and most likely will need a front camber kit
if they are Z spings then yes for sure as they will be dropped even more.
Old Dec 16, 2009 | 01:55 PM
mgmarsh39's Avatar
I am debating a drop myself. What camber kit is recommended and does the kit designate the proper camber or do you have to fiddle with it until its right?
Nicksims13
Oct 15, 2015 01:57 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
mushu
Jul 15, 2015 03:55 PM
