hr y pipe
hr y pipe
anyone know the difference between the 07 and up 350z hr y pipe and the 05 g35x y pipe? they look identicle minus the mounts? just wondering if the inlet and outlet diameters are any different?
They don't look identical. In the HR Y Pipe the two pipes that connect from the cats extend further back before becoming one pipe than the DE Y Pipe (or am I wrong and the g35x y pipe is different from the other DE y pipes).
This thread pretty much explains it all.
https://g35driver.com/forums/intake-...-2003-g35.html
Supposedly you will get better throttle response. Dyno showed +5hp and +3 torque I believe.
6MT Coupe
https://g35driver.com/forums/4515278-post568.html
Scroll down for the HR dia...
can you use a g35 coupe midpipe with the hr y pipe or u have to only use a 350z midpipe? when putting on a hr y pipe on a g35 sedan? because i wanna do my set up as "hr y pipe+coupe midpipe+magnaflow muffler"?
