Dash Lights staying on Please Help!
Old Aug 29, 2004 | 01:38 PM
Tfasano's Avatar
I just started my car and the Brake, Slip and VDC off lights are all on and staying on. I tried restarting the car and nothing. Then I tried resetting the computer and nothing. Anyone have this happen before? What should I do?
www.nypokertour.com
Old Aug 29, 2004 | 04:23 PM
Tfasano's Avatar
Re: Dash Lights staying on Please Help!
Someones gotta know whats going on. I just tried disconnecting the battery for 20 minutes and that didn't work either. WTF????
www.nypokertour.com
Old Aug 29, 2004 | 04:41 PM
Speedoholic's Avatar
G (enie) FUNK ERA
Did you mess around with anything in the engine bay? If not, I would take to the dealer.
Good luck.
MY G-ENIE
Old Aug 29, 2004 | 05:16 PM
dave's Avatar
If those lights are on continuously, it means that the ABS and VDC are not working - be careful if you do drive.
People have reported this after doing burnouts or drifting. If you haven't been doing anything like that., I would take it to the dealer.
2004.5 DG/G 5AT Coupe with all options
Sidemarker turnsignal mod
GroundingGear™
2003 Yamaha YZF600R
Old Aug 29, 2004 | 07:17 PM
Msedanman's Avatar
O.F. Administrator
Yes bro. This issue has come up a few times b4 and it's explained HERE
This thread leads you to another thread (Merlin's) in Mods and Tech Forum HERE which explains your problem.
Your dealer should be familiar with this issue.
G/L
Colin.
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old Aug 30, 2004 | 12:57 PM
hoshtaylor's Avatar
It's a brake sensor recall...mine just started up again last week for the second time since I've had the car...just take it in and the dealer will take care of it.
"Operator, give me the number for 911!"
- Homer Simpson
Old Aug 30, 2004 | 04:52 PM
Tfasano's Avatar
The brake lights seem to be working fine. Does this rule out the brake sensor?
www.nypokertour.com
Old Aug 30, 2004 | 05:27 PM
hoshtaylor's Avatar
I replied to your email...
Also...my guy at Infiniti also told me to check the brake fluid level as this has also been known to cause the brake and slip lights to come on...like I said...mine started again last week and I checked and my brake fluid level is fine...so it must be my sensor again. I'm taking it in Wed.
- Homer Simpson
Old Sep 5, 2004 | 08:36 AM
Tfasano's Avatar
Washed the car yesterday and noticed that one of the wheels was filthy, so I checked my brake fluid level and sure enough it was nearly empty. Turns out I must have loosened up the brake line when I installed the spacers. I tightened up the bolt and added fluid and wallah the lights went off.
Thanks for your help everyone!
www.nypokertour.com
Mry
Mar 3, 2023 01:03 AM
wonderizm
Sep 24, 2015 03:09 AM
attarday
Jul 15, 2015 04:03 PM
