Hard time starting up in cold weather.
Old Dec 18, 2012 | 07:59 PM
zarbatad's Avatar
maybe its the idle air control valve??
Old Dec 18, 2012 | 08:01 PM
VisualSeven's Avatar
just had this problem today when i walked out of school trying to start my car and i was about to yell loud as **** in the parking lot. After three cranks it finally started
Old Dec 18, 2012 | 08:10 PM
Darkstar752's Avatar
There is no idle air control valve on the G35
Old Dec 19, 2012 | 02:09 AM
Exceptional's Avatar
I have the same problem, but I never got it fixed, I just give it a very small amount of gas when I start my car up. BUT I did have it diagnosed, it can be one of two things,
1. throttle body needs to be cleaned
2. idle re-learn needs to be done
Old Dec 19, 2012 | 03:08 AM
SAMzG35's Avatar
G35
What oil are you using?
Old Dec 19, 2012 | 07:40 AM
kjchevy3's Avatar
New MAF yesterday and a nice strong start this morning. No rpm drop until she started warming up. Also had the injectors cleaned and she is purring.
Old Dec 23, 2012 | 12:37 AM
garreTT008's Avatar
My car has been doing this as well... Being in Edmonton it is getting COLD. At -30 it will die but on the second start up, it's perfect.
I'm going to try all of methods here (Clean MAF, Clean the throttle body, and use the gasline antifreeze) and see what happens.
Hopefully all goes well!
Old Dec 23, 2012 | 12:52 AM
SAMzG35's Avatar
G35
That sucks Garrett. Good luck!
Old Dec 23, 2012 | 01:03 AM
garreTT008's Avatar
Thank you!
It's not too bad and it happened for the first time today. I shouldn't have parked outside but oh well. It's supposed to get down to -34 on Christmas Day . She's in the garage now . I'll have to do some maintenance this summer for sure. You should come down this summer .
Old Dec 23, 2012 | 01:24 AM
SAMzG35's Avatar
G35
Thanks man, Mine been parked for a while. I started it today -25 *C had a rough start but once she fired up it was no problem at all. Its also parked outside. Not sure to why yours is going this. Any CEL codes?
I will for sure, Hopefully if I have my wrap done in time I'll be there for the UC meet. I'm considering a turbo kit from Sasha as well. So I would have to come down for the install/tune.
Is it still your DD? Any trouble on the snow this year? lol
Old Dec 23, 2012 | 06:53 PM
adamj27's Avatar
I had this issue and swapped batteries, it starts good now. Just extremely noisy until it reaches operating temp.
Does your block heater make any sound at all? Every other car I've had made a slight whirring sound or at least an electrical sound by the element, the G is silent. I'm not sure if its even working.
Not looking forward to this weeks forecast in Edmonton either :/
andyg35c1
Aug 29, 2015 03:37 PM
sahizzle110
Jul 29, 2015 11:36 AM
TinoNT
Jul 24, 2015 12:16 PM
