Z-Tube = loss of low end torque?
Old Sep 1, 2004 | 12:42 AM
JKDman's Avatar
Just had to ask. With all this talk about CAIs and intakes reducing low end torque/acceleration but increasing it at higher RPMs, just wondering if it's the same with the Z-Tube.
Well? Is it?
| 2004 G35 Coupe 6MT | Diamond Graphite/Graphite | Premium Pkg | Aero Pkg | Navigation | SKYLINE+GT350 emblems | Clear Corners | 35% & 50% Tints |
Old Sep 1, 2004 | 01:07 AM
JKDman's Avatar
Re: Z-Tube = loss of low end torque?
That's what i thought. But i've red people saying how they feel that their aftermarket/non-stock intakes are creating a loss of power at lower RPMs but more power at higher.
Old Sep 1, 2004 | 07:37 AM
Catatafish's Avatar
Speculation based on he said she said. Actual measurements I've seen indicate that all the aftermarket intakes offer no significant difference on the low end and between 0-3 HP on the top end.
Basing my opinion on the data on the FL and CA dyno days, Dave Os threads regarding intake temp measurements, mathematics and fact offered by Q45Tech, and my own measurements with a G Tech Comp in controlled conditions.
2004.5 Coupe/5AT/Ivory/Everything but front spoiler/Nismo CAI/Crawford V5/Crawford Cats
Old Sep 1, 2004 | 08:32 AM
Q45tech's Avatar
One consideration is that oem use intake tuning prior to TB to try to improve cruise fuel economy at low rpms. The need to boost marketing HP has limited this effectiveness.
But you never know if your changes might reduce mpg in the 1500-2400 rpm light load range. Some of the tuned effects of sound suppression.
Now plenum [hemholtz resonant tuning] and runner inside diameters are a special case where enlarging them will decrease the very low end torque because the pivot point [think seesaw torque peak rpm] will shift higher.
Old Sep 1, 2004 | 10:47 AM
winw's Avatar
I think that's not possible based on my simple observation. The z tube is the same diameter and shape as the stock tube, except there are no sound baffles on the z tube. I don't think the z tube does anything except allow sound to escape from the intake.
<img src="https://g35driver.com/rides/spec/pix/winw_1093819995.jpg">
Old Sep 1, 2004 | 11:06 AM
dothemath's Avatar
Someone posted a dyno sheet before and after z-tube, and there was a drop in rpm<3000, but an increase after that. I believe the baffles in the stock pipe cause more turbulance in the air, giving a better mix of air and fuel in the cylinder, hence more low end torque. As the rpm's pick up however, the faster rate and increased volume of the air allowed by the smooth z-tube increases power and torque. I thought a bit about this before buying a z-tube, since I usually drvie with not alot of rpm, but if your getting on it... your rpm's will easily be above 3000. And the sound... is sweet.
Ivory Pearl Coupe/Willow Interior
6mt Base Model
Aero Package only option
G35VSHNG37
Oct 25, 2015 08:43 PM
yosip1115
Aug 26, 2015 10:46 AM
wuppiedog
Aug 7, 2015 11:16 AM
